Hello,
I just plugged a new Harmony Hub in and set it up, then I installed this plugin and ran the discovery. The plugin has found my Harmony Hub and I have put a check mark in all of the boxes (Enabled, Use Activity, Use Devices, Use Sleep) but the only device that is created it the Root device. Is there a trick to get the plugin to connect to the hub? On the config page (Device Configuration Tab) if I click on the Select a Hub drop down, the hub doesn't show up. I left all of the settings on the General Configuration tab default.
Any help would be greatly apprieciated!
Thank you!
Thank you!
