New user - Cannot Find up auto
  • sirmeili
    Originally posted by harvito View Post
    I'm good - need to learn to search and read better - sorry
    So you are good? Sorry I've been MIA. we had a major release at work and then I got sick for a few days.
  • harvito
  • harvito
    Oh boy - spoke to soon - It has found the hub now but I started to get this - These are the debug logs - I looked at the firewall and it is open for this plugin
    Jun-26 22:29:46 Info The Connection to Hub with ID 66a7f88b24512b0aaeb0e4c7b805f8b458c5a05e was closed
    Jun-26 22:29:46 Debug Connection status: Disconnected
    Jun-26 22:29:46 Debug Connection Closed to Hub: 66a7f88b24512b0aaeb0e4c7b805f8b458c5a05e; with guid: 3d51fa26-d0d0-482d-9eea-05a639f78bf6; Where: ; Unexpectedly disconnected?: False
    Jun-26 22:29:46 Error The Connection to Hub with ID 66a7f88b24512b0aaeb0e4c7b805f8b458c5a05e failed with stack trace: at System.Net.Sockets.TcpClient..ctor(String hostname, Int32 port) at HarmonyHub.Client.Connect(Int32 heartbeatInterval)
    Jun-26 22:29:46 Error The Connection to Hub with ID 66a7f88b24512b0aaeb0e4c7b805f8b458c5a05e failed with message: No connection could be made because the target machine actively refused it 192.168.7.230:5222
    Jun-26 22:29:45 Debug Debug Message for Hub 66a7f88b24512b0aaeb0e4c7b805f8b458c5a05e: Attempting to connect to IP: 192.168.x.x on port 5222
    Jun-26 22:29:45 Debug Hub: 66a7f88b24512b0aaeb0e4c7b805f8b458c5a05e Connection Attempt 77
    Jun-26 22:29:45 Debug Connection status: Disconnected
    Jun-26 22:29:45 Info The Connection to Hub with ID 66a7f88b24512b0aaeb0e4c7b805f8b458c5a05e was closed
    Jun-26 22:29:45 Debug Connection Closed to Hub: 66a7f88b24512b0aaeb0e4c7b805f8b458c5a05e; with guid: a997ce49-bcb1-47b7-beda-a2ca5a41e287; Where: ; Unexpectedly disconnected?: False
    Jun-26 22:29:45 Error The Connection to Hub with ID 66a7f88b24512b0aaeb0e4c7b805f8b458c5a05e failed with stack trace: at System.Net.Sockets.TcpClient..ctor(String hostname, Int32 port) at HarmonyHub.Client.Connect(Int32 heartbeatInterval)
    Jun-26 22:29:45 Error The Connection to Hub with ID 66a7f88b24512b0aaeb0e4c7b805f8b458c5a05e failed with message: No connection could be made because the target machine actively refused it 192.168.7.230:5222
    Jun-26 22:29:44 Debug Debug Message for Hub 66a7f88b24512b0aaeb0e4c7b805f8b458c5a05e: Attempting to connect to IP: 192.168.x.x on port 5222
    Jun-26 22:29:44 Debug Hub: 66a7f88b24512b0aaeb0e4c7b805f8b458c5a05e Connection Attempt 20
  • harvito
    Figured it out - I had to go on my homeseer hub and found windows needed me to allow the connection - All good for now
  • harvito
    started a topic New user - Cannot Find up auto
    I just got a hub and it is all setup - I downloaded the latest BETA of this plugin 3.1.0.19. When I try to auto find the hub if comes up empty. If I try to add the IP and find it the hub refuses the connection
    Jun-26 22:01:58 Debug Was a new hub found at IP? False
    Jun-26 22:01:58 Debug Is hub connected?: False
    Jun-26 22:01:58 Error The Connection to Hub with ID failed with stack trace: at System.Net.Sockets.TcpClient..ctor(String hostname, Int32 port) at HarmonyHub.Client.Connect(Int32 heartbeatInterval)
    Jun-26 22:01:58 Error The Connection to Hub with ID failed with message: No connection could be made because the target machine actively refused it 192.168.x.x:5222
    Jun-26 22:01:57 Debug Debug Message for Hub : Attempting to connect to IP: 192.168.x.x on port 5222
    Jun-26 22:01:57 Debug CheckAndStoreHub: Starting to connect to IPAddress: 192.168.x.x
    Jun-26 22:01:57 Debug new Hub with IP address (192.168.x.x) provided. Is it valid? True
    Jun-26 22:01:57 Debug Posting back data on page (MeiHarmonyHub_Config) with data: IP_address=192.168.x.x&id=hub_device_add&hub_device_add=Su bmit
    Jun-26 22:01:57 Info Page MeiHarmonyHub_Config; Data IP_address=192.168.x.x&id=hub_device_add&hub_device_add=Su bmit
    I got this doing an auto -
    Jun-26 22:06:30 Debug Posting back data on page (MeiHarmonyHub_Config) with data: IP_address=&id=hub_device_discover&hub_device_discover=Submi t
    Jun-26 22:06:30 Info Page MeiHarmonyHub_Config; Data IP_address=&id=hub_device_discover&hub_device_discover=Submi t
    Jun-26 22:06:27 Info Page MeiHarmonyHub_Config
