Meiharmony not communicating with Hub
  • sirmeili
    The Profit Have you tried restarting HS3 or your computer? I find it odd it just stopped working. did you upgrade the plugin to a newer version?
    Sgetschel I have yet to try an HS3 -> HS4 converions, but HST said that this should just work. can you try turning on debugging and capturing a debug log?
  • Sgetschel
    I am having the same issue. I just upgraded to HS4 Pro from HS3. Everything was working fine in HS3 but it is not communicating with the hub in HS4. I have tried the above suggestions with no success.
  • The Profit
    Originally posted by sirmeili View Post
    Do you have XMPP enabled on the hub?
    https://forums.homeseer.com/forum/au...plugin-to-work
    Yes. When I originally set it up with the plugin I had enabled XMPP and it was working fine until July 22nd. I don't see any errors in the log. I turned on debug for the plugin and then clicked on the "Connect" button for the HarmonyHub Root device, I've pasted the log below:
    Aug-07 3:32:24 PM Debug Hub should now be connected.
    Aug-07 3:32:24 PM Debug Disconnecting: Hub: XXXXX, Client is connected?: No
    Aug-07 3:32:24 PM Debug Connecting: Hub: XXXXX, Is there a client?: Yes
    Aug-07 3:32:24 PM Debug Connecting: Hub: XXXXXX, KnownDevice Connection Status: FailedToConnect
    Aug-07 3:32:24 PM Debug Starting Connect to Hub: XXXXX
    Aug-07 3:32:24 PM Device Control Device: MeiHarmonyHub MeiHarmonyHub Harmony Hub Hub to Connect (1) by/from: CAPI Control Handler
    Aug-07 3:32:23 PM Debug HS Config Changed: Relationship,Relationship for device ref: 1780
    Aug-07 3:32:23 PM Debug HS Config Changed: Relationship,Relationship for device ref: 1779
    Aug-07 3:32:23 PM Debug HS Config Changed: Relationship,Relationship for device ref: 1777
    Aug-07 3:32:23 PM Debug HS Config Changed: Relationship,Relationship for device ref: 1776
    Aug-07 3:32:23 PM Debug HS Config Changed: AdditionalDisplayData for device ref: 1133
    Aug-07 3:32:14 PM Info KnownDevices: {"XXXXX":{"UniqueId":"XXXXX","Location":"192.168.1 .44","Name":"Harmony Hub","RemoteID":"16067","Devices":{"685":{"DeviceId" :"635","DeviceRef":1712,"Enabled":true,"DeviceSettings" :{"CommandSettings":{},"CommandNameMappings":{},"Repeat":1 ," RepeatDelay":500,"InterCommandDelay":1}},"66":{"Device Id":"66","DeviceRef":1713,"Enabled":true,"DeviceSettin gs":{"CommandSettings":{},"CommandNameMappings":{},"Repeat ": 1,"RepeatDelay":500,"InterCommandDelay":1}},"68":{"Dev iceId":"68","DeviceRef":1714,"Enabled":true,"DeviceSet tings":{"CommandSettings":{},"CommandNameMappings":{},"Repea t":1,"RepeatDelay":500,"InterCommandDelay":1}},"6578":{" DeviceId":"678","DeviceRef":1715,"Enabled":true,"Device Settings":{"CommandSettings":{},"CommandNameMappings":{},"Re peat":1,"RepeatDelay":500,"InterCommandDelay":1}},"6833" :{"DeviceId":"683","DeviceRef":1716,"Enabled":true,"Dev iceSettings":{"CommandSettings":{},"CommandNameMappings":{}, "Repeat":1,"RepeatDelay":500,"InterCommandDelay":1}},"68 3734 37":{"DeviceId":"683","DeviceRef":1717,"Enabled":true," DeviceSettings":{"CommandSettings":{},"CommandNameMappings": {},"Repeat":1,"RepeatDelay":500,"InterCommandDelay":1}},"68 3 73431":{"DeviceId":"631","DeviceRef":1718,"Enabled":tru e,"DeviceSettings":{"CommandSettings":{},"CommandNameMappi ng s":{},"Repeat":1,"RepeatDelay":500,"InterCommandDelay":1} }," 684":{"DeviceId":"634","DeviceRef":1719,"Enabled": true,"DeviceSettings":{"CommandSettings":{},"CommandNameMapp ings":{},"Repeat":1,"RepeatDelay":500,"InterCommandDelay":1} },"62":{"DeviceId":"6832","DeviceRef":1720,"Enable d":true,"DeviceSettings":{"CommandSettings":{},"CommandNa meM appings":{},"Repeat":1,"RepeatDelay":500,"InterCommandDelay" :1}},"629":{"DeviceId":"629","DeviceRef":1721,"Ena bled":true,"DeviceSettings":{"CommandSettings":{},"CommandNa meMappings":{},"Repeat":1,"RepeatDelay":500,"InterCommandDel ay":1}}},"Remotes":null,"ActivityVoiceControlMappings":nul l, "HubRootDeviceReference":1709,"ActivityDeviceReference": 1710 ,"SleepTimerDeviceReference":1711,"Enabled":true,"CreateA cti vityDevice":true,"CreateDeviceDevices":true,"CreateSleepDevi ce":true}}
    Aug-07 3:32:14 PM Info Plugin Settings: {"MaxConnectionAttempts":0,"MaxMissedHeartbeats":2,"TimeB etw eenConnectionAttempts":5000,"RequestTimeout":15000,"Heartbea tInterval":30000,"DevicePollingInterval":"1.00:00:00","Updat eActivityDeviceOn":2,"DebugLogging":true,"HSLoggingLevel":1, "SettingsVersion":{"Major":3,"Minor":1,"Build":0,"Revisi on": 16,"MajorRevision":0,"MinorRevision":16}}
    Aug-07 3:32:14 PM Info Plugin Version: 3.1.0.16
    Aug-07 3:32:14 PM Info Debug Logging Turned on.
    Aug-07 3:32:14 PM Debug Posting back data on page (MeiHarmonyHub_General_Config) with data: DebugLogging=checked&id=DebugLogging
    Aug-07 3:32:14 PM Info Page MeiHarmonyHub_General_Config; Date DebugLogging=checked&id=DebugLogging
  • sirmeili
  • The Profit
    NP. It doesn't necessarily have to be 15000 but I would make sure that whatever you set it to that the heartbeat interval is more than the request timeout.
    Hello,
    I’m having issues with the hub connecting to your plugin. I have checked all of the above setting you’ve mentioned and nothing seems to get this working. Could you let me know what you need to assist?
  • sirmeili
    Originally posted by CameronHilliard View Post
    I changed this to 15000 and it worked. Thanks for looking into this!
  • CameronHilliard
    2000
  • CameronHilliard
    Can you go to the plugins' general settings and tell me what you have set for "Request Timeout"?
    2000
  • sirmeili
  • CameronHilliard
    I will take a look at your logs after work today.
    Thank you
  • sirmeili
  • CameronHilliard
    started a topic Meiharmony not communicating with Hub
    I have looked at nearly every post in this forum. I assumed my issue was the enable xmpp (which I needed to do) no dice.
    I then checked and made sure I downloaded the latest beta version of the plugin. no dice
    I'm running homeseer on a windows machine. The hub works just fine normally. I don't have to connect through the cloud.
    I've been scouring the forums for 3 hours and I give up. Please assist if you don't mind. Here are the logs I have already turned on the developer debug log
