Cant upgrade from 3.1.0.16 --> 3.1.0.18
    Ran the install several times..
    It shows updated, BUT it still shows the OLD version..
    Jul-17 4:04:39 PM Updater Re-initializing plugin after update.
    Jul-17 4:04:37 PM Updater Install/Update of package MeiHarmonyHub was successful.
    Jul-17 4:04:37 PM Updater Copying file: C:\Program Files (x86)\HomeSeer HS3\html\images\MeiHarmonyHub\Status\remote-icon-rotated.png
    Jul-17 4:04:37 PM Updater Copying file: C:\Program Files (x86)\HomeSeer HS3\html\images\MeiHarmonyHub\remote-icon-rotated.png
    Jul-17 4:04:37 PM Updater Warning File exists, not overwriting: C:\Program Files (x86)\HomeSeer HS3\Config\MeiHarmonyHub\HSPI_MeiHarmonyHubs_KnonwHubs.json
    Jul-17 4:04:37 PM Updater Warning File exists, not overwriting: C:\Program Files (x86)\HomeSeer HS3\Config\MeiHarmonyHub\HSPI_MeiHarmonyHubs_Settings.json
    Jul-17 4:04:37 PM Updater Copying file: C:\Program Files (x86)\HomeSeer HS3\bin\MeiHarmonyHub\Newtonsoft.Json.dll
    Jul-17 4:04:36 PM Updater Copying file: C:\Program Files (x86)\HomeSeer HS3\bin\MeiHarmonyHub\Serilog.Sinks.File.dll
    Jul-17 4:04:36 PM Updater Copying file: C:\Program Files (x86)\HomeSeer HS3\bin\MeiHarmonyHub\Serilog.dll
    Jul-17 4:04:36 PM Updater Copying file: C:\Program Files (x86)\HomeSeer HS3\bin\MeiHarmonyHub\MBPlugins.dll
    Jul-17 4:04:36 PM Updater Copying file: C:\Program Files (x86)\HomeSeer HS3\bin\MeiHarmonyHub\CommandLine.dll
    Jul-17 4:04:36 PM Updater Copying file: C:\Program Files (x86)\HomeSeer HS3\HSPI_MeiHarmonyHub.exe.config
    Jul-17 4:04:36 PM Updater Installing package MeiHarmonyHub
    Jul-17 4:04:36 PM Updater Update HSPI_MeiHarmonyHub.exe downloaded successfully
    Jul-17 4:04:36 PM Info Plugin MeiHarmonyHub with instance: has disconnected
    Jul-17 4:04:36 PM Updater Downloading update: MeiHarmonyHub
    Jul-17 4:04:36 PM Warning Problem shutting down plugin Msg-B:MeiHarmonyHub
    Jul-17 4:04:36 PM Warning Problem shutting down plugin Msg-A:MeiHarmonyHub:The given key was not present in the dictionary.
    Jul-17 4:04:36 PM Updater Plugin is loaded, unloading before updating.
    Jul-17 4:04:36 PM Updater Starting download of updates
    This has been mentioned in other threads, [mention]sirmeili [/mention] is aware of it but hasn’t had a chance to put out a version to correct this issue yet. Hope soon?
    HS4 4.2.6.0 &HSTouch Designer 3.0.80
    Plugin's:
    weatherXML, Jon00 Alexa Helper, Network Monitor, MyQ, Z-Wave
      I must've missed something (or forgot with everything going on). I will put .16 back on and attempt to update to see what is going on. I should have time this week/weekend.
      MeiAutomtion Home
        I must've forgot to post, please try 3.1.0.19. it is in both the beta section and the main section. If not I'll release .20 (which will just be a version update)
        MeiAutomtion Home
          I'm unable to upgrade from 3.1.0.16 --> 3.1.0.18 as well. Has this been fixed? Seems like its been broken for a very long time.
            I moved from HS3 to HS4 a few weeks back and now it shows 3.1.0.16 "OKAY" with no offer to upgrade.
              yes, I will push the newest version out or if you can access the beta, you can install .22. Note that the .16 you're installing is really .18. I just forgot to update the version in the assembly and once I did that, HS won't overwrite my zip file if it has the same name. I'll work on getting the newest version out this week.
              MeiAutomtion Home
