After a power outage caused an unexpected reboot, my MeiHarmony Plugin fails to load at startup and I cannot get it back online. From the startup Log:
9/3/2020 8:57:35 PM ~!~Starting Plug-In~!~Initializing plugin MeiHarmonyHub ...
9/3/2020 8:57:39 PM ~!~Error~!~Initializing plug-in(2): MeiHarmonyHub Instance::Object reference not set to an instance of an object.STACK: at System.Runtime.Remoting.Messaging.LogicalCallContext.Propaga teIncomingHeadersToCallContext(IMessage msg) at System.Runtime.Remoting.Proxies.RealProxy.PrivateInvoke(Mess ageData& msgData, Int32 type) at HomeSeerAPI.IPlugInAPI.InitIO(String port) at Scheduler.clsHSPI.CheckInterfaces()
9/3/2020 8:57:39 PM ~!~Starting Plug-In~!~MeiHarmonyHub loaded in 4316 milliseconds
I tried a reinstall of the plugin, started at a lower version and updated through the beta, no luck. Same issue every time.
I just built a very complex set of TV & Device control pages in HSTouch based off the MeiHarmony devices in Homeseer. I REALLY want to avoid redoing all of that work, so restoring functionality of the currently existing devices is my end goal. If the devices in HomeSeer are replaced, then I have to redo every button in HSTouch.
Any advice would be greatly appreciated.
Thanks.
Thanks.
