ALL sonos are paused when run POWEROFF command via plugin
    Hi,
    Maybe somebody has the same problem.
    I have 2 Harmony HUBS. 1 in bedroom and 1 in the livingroom.
    When i run a HomeSeer PowerOFF command for Livingroom ALL Sonos players are paused. When i run a PowerOFF coomand via the Harmony app then there is no problem (Sonos is not paused)
    Why is this?
    Walter
    Do you have the Sonos players added to your Harmony?
    MeiAutomtion Home
      Hi,
      Yes, I added the Sonos speakers into the Harmony app. When I poweroff the TV set with the app all other Sonos speakers are not paused. When I run poweroff command with the PI then all Sonos speakers are paused in the whole house. You can’t remove the Sonos speakers individually. When you remove it you have to remove all Sonos devices and then the Beam won’t work anymore on my TV set.
      Walter
        That is odd. I am merely sending the same command the app would be sending. I am sending the "power Off" command. You don't happen to have an event you created in HS to do that, do you?
        MeiAutomtion Home
          Im starting PowerOFF when im leaving home . Im temporay disable another event to avoid a trigger.
          This PowerOFF will pause ALL sonos players in the house.
