Welcome to the Sony CX777ES Plug-in Forum
Description
The CX777ES Plugin for Homeseer v2.2 communicates using a available RS232 port.
The CX777ES Plug-in can send Power-On, Power-Off, Pause, Play, and Queue up DVD's or CD's from scripts or from Web based interfaces such as Tom Caldwell's DVD Collection.
Features
Configuration is done with a CX777ES.ini located in the \Config directory.
The contents should look something like the following:
[Config]
ComPort=COM8
Debug=False
Logging=False
Debug turns on the verbose logging feature for HomeSeer's Log
and Logging will create a separate CX777ES.log file in the \Logs directory.
System Requirements
Description
Features
- Small compact .NET2 code for use with HomeSeer 2.2.
- Create Homeseer v2.2 events that controls the Sony CX777ES DVD changer.
- The following are script commands that can be used to control the CX777ES Changer:
PwrOnDVD() --- Powers On Sony CX777ES
PwrOffDVD() --- Powers Off Sony CX777ES
StopDVD() --- Stops DVD Play
PlayDVD() --- Play DVD
PauseDVD() --- Pause and Resume DVD Play
StartDVD(DiscNum) --- Queues Up Disc-Number and begins Play
- Example use in Script or Event:
&hs.plugin("CX777ES").StartDVD(125) --- Changes to Disc number 125 and begins play.
ConfigurationConfiguration is done with a CX777ES.ini located in the \Config directory.
[Config]
ComPort=COM8
Debug=False
Logging=False
System Requirements
- Homeseer version 2.2 or later
- Microsoft .NET VERSION 2
- Available RS232 Port
