Cannot connect to STR-ZA3000ES
  • Cannot connect to STR-ZA3000ES
    Just installed from the updater and get the following error:
    May-10 11:29:19 PM SonyAVR ERROR PollAVR Request has timed out
    May-10 11:28:19 PM SonyAVR ERROR PollAVR Request has timed out
    May-10 11:27:19 PM SonyAVR ERROR PollAVR Request has timed out
    May-10 11:26:19 PM SonyAVR ERROR PollAVR Request has timed out
    May-10 11:25:13 PM SonyAVR ERROR System.Exception: Request has timed out at SonyAVR.Net.SonyAVRClient.SendRequest(JObject jobject, Int32 timeoutInMs) at SonyAVR.Net.SonyAVRClient.GetFeature(String feature) at HSPI_SonyAVR.SonyAVRApp.InitSonyAVRClient()
    May-10 11:25:08 PM SonyAVR INFO Initializing SonyAVR Client
    May-10 11:25:08 PM Plug-In Finished initializing plug-in SonyAVR
    Apart from IP address what else can I check in config? I already made sure the network options are set correctly in the AVR.
    Edit: I tried shutting down the plugin and restarting it:
    May-10 11:49:02 PM SonyAVR ERROR PollAVR Request has timed out
    May-10 11:47:57 PM SonyAVR ERROR System.Exception: Request has timed out at SonyAVR.Net.SonyAVRClient.SendRequest(JObject jobject, Int32 timeoutInMs) at SonyAVR.Net.SonyAVRClient.GetFeature(String feature) at HSPI_SonyAVR.SonyAVRApp.InitSonyAVRClient()
    May-10 11:47:53 PM Updater An item in the Updater is temporarily unavailable: The operation has timed out Item: https://dl.dropbox.com/s/s1mpzz5poizkzud/updates.txt
    May-10 11:47:52 PM SonyAVR INFO Initializing SonyAVR Client
    May-10 11:47:51 PM Plug-In Finished initializing plug-in SonyAVR
    May-10 11:47:51 PM SonyAVR INFO SonyAVR version 3.0.0.4
    May-10 11:47:51 PM Info Plugin SonyAVR has connected. IP:127.0.0.1:52877
    May-10 11:47:50 PM Plug-In Interface SonyAVR is running as a trial, 30 days remaining.
    May-10 11:46:37 PM Info Plugin SonyAVR with instance: has disconnected
    May-10 11:46:37 PM SonyAVR INFO Shutting down SonyAVR Client
    May-10 11:46:37 PM Plug-In Shutting down Plug-In: SonyAVR
    May-10 11:46:19 PM SonyAVR ERROR PollAVR Request has timed out
    I added another instance for another AVR that is at a different firmware level to see if that was the issue but it does not connect either. Also changed the log to debug level:
    May-11 8:42:47 AM SonyAVR DEBUG System.Exception: Request has timed out at SonyAVR.Net.SonyAVRClient.SendRequest(JObject jobject, Int32 timeoutInMs) at SonyAVR.Net.SonyAVRClient.GetFeature(String feature) at HSPI_SonyAVR.SonyAVRApp.PollAVR(Object source, ElapsedEventArgs e)
    May-11 8:42:47 AM SonyAVR ERROR PollAVR Request has timed out
    May-11 8:42:42 AM SonyAVR DEBUG RX:{"id":1,"type":"result","feature":"system.volumedisplay", "value":"db"}{"id":2,"type":"result","feature":"main.power", "value":"off"}{"id":3,"type":"result","feature":"main.power" ,"value":"off"}
    May-11 8:42:42 AM SonyAVR DEBUG TX:{ "id": 3, "type": "get", "feature": "main.power" }
    May-11 8:42:09 AM SonyAVR DEBUG System.Exception: Request has timed out at SonyAVR.Net.SonyAVRClient.SendRequest(JObject jobject, Int32 timeoutInMs) at SonyAVR.Net.SonyAVRClient.GetFeature(String feature) at HSPI_SonyAVR.SonyAVRApp.PollAVR(Object source, ElapsedEventArgs e)
    May-11 8:42:09 AM SonyAVR ERROR PollAVR Request has timed out
    May-11 8:42:04 AM SonyAVR DEBUG RX:{"id":1,"type":"result","feature":"system.volumedisplay", "value":"db"}{"id":2,"type":"result","feature":"main.power", "value":"on"}{"id":3,"type":"result","feature":"main.power", "value":"on"}{"id":4,"type":"result","feature":"main.power", "value":"on"}{"id":5,"type":"result","feature":"main.power", "value":"on"}{"id":6,"type":"result","feature":"main.power", "value":"on"}{"id":7,"type":"result","feature":"main.power", "value":"on"}
    May-11 8:42:04 AM SonyAVR DEBUG TX:{ "id": 7, "type": "get", "feature": "main.power" }
    May-11 8:41:09 AM SonyAVR DEBUG System.Exception: Request has timed out at SonyAVR.Net.SonyAVRClient.SendRequest(JObject jobject, Int32 timeoutInMs) at SonyAVR.Net.SonyAVRClient.GetFeature(String feature) at HSPI_SonyAVR.SonyAVRApp.PollAVR(Object source, ElapsedEventArgs e)
    May-11 8:41:09 AM SonyAVR ERROR PollAVR Request has timed out
    May-11 8:41:04 AM SonyAVR DEBUG RX:{"id":1,"type":"result","feature":"system.volumedisplay", "value":"db"}{"id":2,"type":"result","feature":"main.power", "value":"on"}{"id":3,"type":"result","feature":"main.power", "value":"on"}{"id":4,"type":"result","feature":"main.power", "value":"on"}{"id":5,"type":"result","feature":"main.power", "value":"on"}{"id":6,"type":"result","feature":"main.power", "value":"on"}
    May-11 8:41:04 AM SonyAVR DEBUG TX:{ "id": 6, "type": "get", "feature": "main.power" }
    May-11 8:40:09 AM SonyAVR ERROR PollAVR Request has timed out
    May-11 8:39:47 AM SonyAVR ERROR PollAVR Request has timed out
    May-11 8:39:09 AM SonyAVR ERROR PollAVR Request has timed out
    May-11 8:38:09 AM SonyAVR ERROR PollAVR Request has timed out
    May-11 8:37:33 AM SonyAVR ERROR System.Exception: Request has timed out at SonyAVR.Net.SonyAVRClient.SendRequest(JObject jobject, Int32 timeoutInMs) at SonyAVR.Net.SonyAVRClient.GetFeature(String feature) at HSPI_SonyAVR.SonyAVRApp.InitSonyAVRClient()
    May-11 8:37:28 AM SonyAVR INFO Initializing SonyAVR Client
      I just tried the Sony TV plugin and it connected fine which tells me the problem is likely specific to the AVR plugin and not some other general system problem. Is there a chance that the default port is incorrect? Anything I can check in the config files?
        There are some "RX" lines in your logs, meaning the plugin receive some info from the AVR, so at least one of your instance connects fine. The problem seems more related to the way the messages are sent. Could you try to check which instance gets the RX and only enable this one, then post the full debug logs.
        Are you on Linux or Windows?
          I'm on Windows. I'll see if I can figure out which instance is responding and get some debug info posted. Thanks.
          Here is the log of the fist instance starting up:
          ay-13 11:50:00 AM SonyAVR ERROR System.Exception: Request has timed out at SonyAVR.Net.SonyAVRClient.SendRequest(JObject jobject, Int32 timeoutInMs) at SonyAVR.Net.SonyAVRClient.GetFeature(String feature) at HSPI_SonyAVR.SonyAVRApp.InitSonyAVRClient()
          May-13 11:50:00 AM SonyAVR DEBUG System.Exception: Request has timed out at SonyAVR.Net.SonyAVRClient.SendRequest(JObject jobject, Int32 timeoutInMs) at SonyAVR.Net.SonyAVRClient.GetFeature(String feature) at HSPI_SonyAVR.SonyAVRApp.PollAVR(Object source, ElapsedEventArgs e)
          May-13 11:50:00 AM SonyAVR ERROR PollAVR Request has timed out
          May-13 11:49:55 AM SonyAVR DEBUG RX:{"id":1,"type":"result","feature":"system.volumedisplay", "value":"db"}
          May-13 11:49:55 AM SonyAVR DEBUG TX:{ "id": 1, "type": "get", "feature": "system.volumedisplay" }
          May-13 11:49:55 AM SonyAVR INFO Initializing SonyAVR Client
          May-13 11:49:55 AM SonyAVR INFO Shutting down SonyAVR Client
          May-13 11:49:55 AM SonyAVR DEBUG System.IO.IOException: Unable to read data from the transport connection: An existing connection was forcibly closed by the remote host. ---> System.Net.Sockets.SocketException: An existing connection was forcibly closed by the remote host at System.Net.Sockets.Socket.Receive(Byte[] buffer, Int32 offset, Int32 size, SocketFlags socketFlags) at System.Net.Sockets.NetworkStream.Read(Byte[] buffer, Int32 offset, Int32 size) --- End of inner exception stack trace --- at System.Net.Sockets.NetworkStream.Read(Byte[] buffer, Int32 offset, Int32 size) at SonyAVR.Net.SonyAVRClient.ListenForData()
          May-13 11:49:55 AM SonyAVR DEBUG TX:{ "id": 2, "type": "get", "feature": "main.power" }
          May-13 11:49:02 AM Updater An item in the Updater is temporarily unavailable: The operation has timed out Item: http://www.myautomatedhome.net/HS3/w...ml_updater.txt
          May-13 11:48:57 AM Updater An item in the Updater is temporarily unavailable: The operation has timed out Item: http://www.myautomatedhome.net/HS3/r...rt_updater.txt
          May-13 11:48:55 AM SonyAVR ERROR System.Exception: Request has timed out at SonyAVR.Net.SonyAVRClient.SendRequest(JObject jobject, Int32 timeoutInMs) at SonyAVR.Net.SonyAVRClient.GetFeature(String feature) at HSPI_SonyAVR.SonyAVRApp.InitSonyAVRClient()
          May-13 11:48:50 AM SonyAVR DEBUG TX:{ "id": 1, "type": "get", "feature": "system.volumedisplay" }
          May-13 11:48:50 AM SonyAVR INFO Initializing SonyAVR Client
          May-13 11:48:49 AM Starting Plug-In Plugin SonyAVR started successfully in 78 milliseconds
          May-13 11:48:49 AM SonyAVR INFO SonyAVR version 3.0.0.4
          May-13 11:48:49 AM Starting Plug-In Initializing plugin SonyAVR ...
          May-13 11:48:49 AM Info Plugin SonyAVR has connected. IP:127.0.0.1:59060
          May-13 11:48:48 AM Plug-In Finished initializing plug-in SonyAVR
          May-13 11:48:48 AM Plug-In Interface SonyAVR is running as a trial, 28 days remaining.
            Polling Errors for instance 1. (Instance 2 disabled)
            ay-13 11:55:00 AM SonyAVR DEBUG System.Exception: Request has timed out at SonyAVR.Net.SonyAVRClient.SendRequest(JObject jobject, Int32 timeoutInMs) at SonyAVR.Net.SonyAVRClient.GetFeature(String feature) at HSPI_SonyAVR.SonyAVRApp.PollAVR(Object source, ElapsedEventArgs e)
            May-13 11:55:00 AM SonyAVR ERROR PollAVR Request has timed out
            May-13 11:54:55 AM SonyAVR DEBUG RX:{"id":1,"type":"result","feature":"system.volumedisplay", "value":"db"}{"id":2,"type":"result","feature":"main.power", "value":"on"}{"id":3,"type":"result","feature":"main.power", "value":"on"}{"id":4,"type":"result","feature":"main.power", "value":"on"}{"id":5,"type":"result","feature":"main.power", "value":"on"}{"id":6,"type":"result","feature":"main.power", "value":"on"}
            May-13 11:54:55 AM SonyAVR DEBUG TX:{ "id": 6, "type": "get", "feature": "main.power" }
            May-13 11:54:00 AM SonyAVR DEBUG System.Exception: Request has timed out at SonyAVR.Net.SonyAVRClient.SendRequest(JObject jobject, Int32 timeoutInMs) at SonyAVR.Net.SonyAVRClient.GetFeature(String feature) at HSPI_SonyAVR.SonyAVRApp.PollAVR(Object source, ElapsedEventArgs e)
            May-13 11:54:00 AM SonyAVR ERROR PollAVR Request has timed out
            May-13 11:53:55 AM SonyAVR DEBUG RX:{"id":1,"type":"result","feature":"system.volumedisplay", "value":"db"}{"id":2,"type":"result","feature":"main.power", "value":"on"}{"id":3,"type":"result","feature":"main.power", "value":"on"}{"id":4,"type":"result","feature":"main.power", "value":"on"}{"id":5,"type":"result","feature":"main.power", "value":"on"}
            May-13 11:53:55 AM SonyAVR DEBUG TX:{ "id": 5, "type": "get", "feature": "main.power" }
            May-13 11:53:00 AM SonyAVR DEBUG System.Exception: Request has timed out at SonyAVR.Net.SonyAVRClient.SendRequest(JObject jobject, Int32 timeoutInMs) at SonyAVR.Net.SonyAVRClient.GetFeature(String feature) at HSPI_SonyAVR.SonyAVRApp.PollAVR(Object source, ElapsedEventArgs e)
            May-13 11:53:00 AM SonyAVR ERROR PollAVR Request has timed out
            May-13 11:52:55 AM SonyAVR DEBUG RX:{"id":1,"type":"result","feature":"system.volumedisplay", "value":"db"}{"id":2,"type":"result","feature":"main.power", "value":"on"}{"id":3,"type":"result","feature":"main.power", "value":"on"}{"id":4,"type":"result","feature":"main.power", "value":"on"}
            May-13 11:52:55 AM SonyAVR DEBUG TX:{ "id": 4, "type": "get", "feature": "main.power" }
            May-13 11:52:00 AM SonyAVR DEBUG System.Exception: Request has timed out at SonyAVR.Net.SonyAVRClient.SendRequest(JObject jobject, Int32 timeoutInMs) at SonyAVR.Net.SonyAVRClient.GetFeature(String feature) at HSPI_SonyAVR.SonyAVRApp.PollAVR(Object source, ElapsedEventArgs e)
            May-13 11:52:00 AM SonyAVR ERROR PollAVR Request has timed out
            May-13 11:51:55 AM SonyAVR DEBUG RX:{"id":1,"type":"result","feature":"system.volumedisplay", "value":"db"}{"id":2,"type":"result","feature":"main.power", "value":"on"}{"id":3,"type":"result","feature":"main.power", "value":"on"}
            May-13 11:51:55 AM SonyAVR DEBUG TX:{ "id": 3, "type": "get", "feature": "main.power" }
            May-13 11:51:00 AM SonyAVR DEBUG System.Exception: Request has timed out at SonyAVR.Net.SonyAVRClient.SendRequest(JObject jobject, Int32 timeoutInMs) at SonyAVR.Net.SonyAVRClient.GetFeature(String feature) at HSPI_SonyAVR.SonyAVRApp.PollAVR(Object source, ElapsedEventArgs e)
            May-13 11:51:00 AM SonyAVR ERROR PollAVR Request has timed out
            May-13 11:50:55 AM SonyAVR DEBUG RX:{"id":1,"type":"result","feature":"system.volumedisplay", "value":"db"}{"id":2,"type":"result","feature":"main.power", "value":"on"}
            May-13 11:50:55 AM SonyAVR DEBUG TX:{ "id": 2, "type": "get", "feature": "main.power" }
            May-13 11:50:00 AM SonyAVR ERROR System.Exception: Request has timed out at SonyAVR.Net.SonyAVRClient.SendRequest(JObject jobject, Int32 timeoutInMs) at SonyAVR.Net.SonyAVRClient.GetFeature(String feature) at HSPI_SonyAVR.SonyAVRApp.InitSonyAVRClient()
              Config File:
              [REMOTE_CONTROLS]
              1###name=Up
              1###command=GUI.up
              1###value=pulse
              2###name=Down
              2###command=GUI.down
              2###value=pulse
              3###name=Left
              3###command=GUI.left
              3###value=pulse
              4###name=Right
              4###command=GUI.right
              4###value=pulse
              5###name=Home
              5###command=GUI.home
              5###value=pulse
              6###name=Enter
              6###command=GUI.enter
              6###value=pulse
              7###name=Return
              7###command=GUI.return
              7###value=pulse
              8###name=Display
              8###command=GUI.display
              8###value=pulse
              9###name=Options
              9###command=GUI.optionmenu
              9###value=pulse
              10###name=Amp Menu
              10###command=GUI.ampmenu
              10###value=pulse
              11###name=Play
              11###command=GUI.play
              11###value=pulse
              12###name=Pause
              12###command=GUI.pause
              12###value=pulse
              13###name=Stop
              13###command=GUI.stop
              13###value=pulse
              14###name=Next
              14###command=GUI.next
              14###value=pulse
              15###name=Previous
              15###command=GUI.previous
              15###value=pulse
              16###name=FF
              16###command=GUI.ff
              16###value=pulse
              17###name=FR
              17###command=GUI.fr
              17###value=pulse
              18###name=Preset+
              18###command=tuner.preset+
              18###value=pulse
              19###name=Preset-
              19###command=tuner.preset-
              19###value=pulse
              20###name=Custom Preset 1
              20###command=custompreset1.select
              21###name=DSD On
              21###value=on
              21###command=audio.dsdnative
              22###name=DSD Off
              22###value=off
              22###command=audio.dsdnative
              23###name=HDMI Out A
              23###value=A
              23###command=hdmi.out
              24###name=HDMI Out B
              24###value=B
              24###command=hdmi.out
              25###name=HDMI Out AB
              25###value=AB
              25###command=hdmi.out
              26###name=HDMI Out Off
              26###value=Off
              26###command=hdmi.out
              27###name=Soundfield+
              27###value=+
              27###command=audio.soundfield
              28###name=Soundfield-
              28###value=-
              28###command=audio.soundfield
              [AVR]
              ip=192.168.0.98
              [GENERAL]
              poll_interval=1
              log_level=Debug
                Now just getting this once per poll cycle (device page still shows root as disconnected):
                May-13 12:48:34 PM SonyAVR DEBUG System.Exception: Request has timed out at SonyAVR.Net.SonyAVRClient.SendRequest(JObject jobject, Int32 timeoutInMs) at SonyAVR.Net.SonyAVRClient.GetFeature(String feature) at HSPI_SonyAVR.SonyAVRApp.PollAVR(Object source, ElapsedEventArgs e)
                May-13 12:48:34 PM SonyAVR ERROR PollAVR Request has timed out
                May-13 12:48:29 PM SonyAVR DEBUG RX:{"id":1,"type":"result","feature":"system.volumedisplay", "value":"db"}{"id":2,"type":"result","feature":"main.power", "value":"on"}{"id":3,"type":"result","feature":"main.power", "value":"on"}{"id":4,"type":"result","feature":"main.power", "value":"on"}{"id":5,"type":"result","feature":"main.power", "value":"on"}{"id":6,"type":"result","feature":"main.power", "value":"on"}{"id":7,"type":"result","feature":"main.power", "value":"on"}{"id":8,"type":"result","feature":"main.power", "value":"on"}{"id":9,"type":"result","feature":"main.power", "value":"on"}{"id":10,"type":"result","feature":"main.power" ,"value":"on"}{"id":11,"type":"result","feature":"main.power ","value":"on"}{"id":12,"type":"result","feature":"main.powe r","value":"on"}{"id":13,"type":"result","feature":"main.pow er","value":"on"}{"id":14,"type":"result","feature":"main.po wer","value":"on"}{"id":15,"type":"result","feature":"main.p ower","value":"on"}{"id":16,"type":"result","feature":"main. power","value":"on"}{"id":17,"type":"result","feature":"main .power","value":"on"}{"id":18,"type":"result","feature":"mai n.power","value":"on"}{"id":19,"type":"result","feature":"ma in.power","value":"on"}{"id":20,"type":"result","feature":"m ain.power","value":"on"}{"id":21,"type":"result","feature":" main.power","value":"on"}{"id":22,"type":"result","feature": "main.power","value":"on"}{"id":23,"type":"result","feature" :"main.power","value":"on"}{"id":24,"type":"result","feature ":"main.power","value":"on"}{"id":25,"type":"result","featur e":"main.power","value":"on"}{"id":26,"type":"result","featu re":"main.power","value":"on"}{"id":27,"type":"result","feat ure":"main.power","value":"on"}{"id":28,"type":"result","fea ture":"main.power","value":"on"}{"id":29,"type":"result","fe ature":"main.power","value":"on"}{"id":30,"type":"result","f eature":"main.power","value":"on"}{"id":31,"type":"result"," feature":"main.power","value":"on"}{"id":32,"type":"result", "feature":"main.power","value":"on"}{"id":33,"type":"result" ,"feature":"main.power","value":"on"}{"id":34,"type":"result ","feature":"main.power","value":"on"}{"id":35,"type":"resul t","feature":"main.power","value":"on"}{"id":36,"type":"resu lt","feature":"main.power","value":"on"}{"id":37,"type":"res ult","feature":"main.power","value":"on"}{"id":38,"type":"re sult","feature":"main.power","value":"on"}{"id":39,"type":"r esult","feature":"main.power","value":"on"}{"id":40,"type":" result","feature":"main.power","value":"on"}
                May-13 12:48:29 PM SonyAVR DEBUG TX:{ "id": 40, "type": "get", "feature": "main.power" }
                  the plugin expects a message coming from the AVR to end with "\n". It doesn't seem to be the case with your device.
                  In version 3.0.0.5 available here, I have added the possibility to log to a file. At the very bottom of the config page, check the "Log to File" checkbox, set the "file Log Level" to Debug, then restart the plugin and post here the log file located in Logs/SonyAVR.txt
                  thanks
                    thanks
                    Will do. I see updater override.txt actually downloads as a php file... what do I need to open that?
                      it shouldn't be downloaded as a php file, it's a simple text file that you need to put in your Homeseer dir.
                      try another browser
                        Here is the log file. Root device still shows as "disconnected"
                        May-14 16:28:40 DEBUG TX:{
                        "id": 2,
                        "type": "get",
                        May-14 16:28:40 DEBUG RX:{"id":1,"type":"result","feature":"system.volumedisplay", "value":"db"}{"id":2,"type":"result","feature":"main.power", "value":"on"}
                        May-14 16:28:45 ERROR PollAVR Request has timed out
                        May-14 16:28:45 DEBUG System.Exception: Request has timed out
                        May-14 16:29:40 DEBUG TX:{
                        "id": 3,
                        "type": "get",
                        May-14 16:29:40 DEBUG RX:{"id":1,"type":"result","feature":"system.volumedisplay", "value":"db"}{"id":2,"type":"result","feature":"main.power", "value":"on"}{"id":3,"type":"result","feature":"main.power", "value":"on"}
                        May-14 16:29:45 ERROR PollAVR Request has timed out
                        May-14 16:29:45 DEBUG System.Exception: Request has timed out
                        May-14 16:30:40 DEBUG TX:{
                        "id": 4,
                        "type": "get",
                        May-14 16:30:40 DEBUG RX:{"id":1,"type":"result","feature":"system.volumedisplay", "value":"db"}{"id":2,"type":"result","feature":"main.power", "value":"on"}{"id":3,"type":"result","feature":"main.power", "value":"on"}{"id":4,"type":"result","feature":"main.power", "value":"on"}
                        May-14 16:30:45 ERROR PollAVR Request has timed out
                        May-14 16:30:45 DEBUG System.Exception: Request has timed out
                        May-14 16:31:40 DEBUG TX:{
                        "id": 5,
                        "type": "get",
                        May-14 16:31:40 DEBUG RX:{"id":1,"type":"result","feature":"system.volumedisplay", "value":"db"}{"id":2,"type":"result","feature":"main.power", "value":"on"}{"id":3,"type":"result","feature":"main.power", "value":"on"}{"id":4,"type":"result","feature":"main.power", "value":"on"}{"id":5,"type":"result","feature":"main.power", "value":"on"}
                        May-14 16:31:45 ERROR PollAVR Request has timed out
                        May-14 16:31:45 DEBUG System.Exception: Request has timed out
                        May-14 16:32:00 INFO Shutting down SonyAVR Client
                        May-14 16:32:52 INFO SonyAVR version 3.0.0.5
                        May-14 16:32:53 INFO Initializing SonyAVR Client
                        May-14 16:32:53 DEBUG TX:{
                        "id": 1,
                        "type": "get",
                        May-14 16:32:53 DEBUG RX:{"id":1,"type":"result","feature":"system.volumedisplay", "value":"db"}
                        May-14 16:32:58 ERROR System.Exception: Request has timed out
                        May-14 16:33:58 DEBUG TX:{
                        "id": 2,
                        "type": "get",
                        May-14 16:33:58 DEBUG RX:{"id":1,"type":"result","feature":"system.volumedisplay", "value":"db"}{"id":2,"type":"result","feature":"main.power", "value":"on"}
                          thanks but can you attach the file directly, or send it to me at spud.webb.4@gmail.com. The forum formatting may remove some line feed characters.
                            Email sent.
                              Email sent.
                              hmmm, I didn't received any email
