Errors flood HS log
    Errors flood HS log
    I'm wondering how I can control the logging of the plugin. It all works as expected but when the TV is off, the HS log every minute shows a log entry as follows:
    ERROR System.Net.Sockets.SocketException (0x80004005): A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond xxx.xxx.xxx.xxx:20060 at System.Net.Sockets.TcpClient..ctor(String hostname, Int32 port) at SonyTV.Net.SonyTVClient..ctor(String serverAddress, Int32 serverPort) at HSPI_SonyTV.SonyTVApp.InitSonyTVClient()
    Log level is set to 'Error' and poll for status every 60m. With that, I had expected to see this message every hour at most.
    Is this expected behaviour? I'm using version 3.0.0.6
    I"m getting these too... Not every minute... I poll every 3 minutes and get these every 5 to 15. minutes
    My home is smarter than your honor roll student.
