Haunted Sony TV Issue
  • Haunted Sony TV Issue
    Hi Spud...
    I've got two good ones for you.
    I recently installed a Sony A9G77 OLED TV running android. Your plugin works great, but seems to disconnect very regularly.
    Dec-03 11:52:14 PM SonyTV ERROR System.Net.Sockets.SocketException (0x80004005): No connection could be made because the target machine actively refused it 10.10.10.192:20060 at System.Net.Sockets.TcpClient..ctor(String hostname, Int32 port) at SonyTV.Net.SonyTVClient..ctor(String serverAddress, Int32 serverPort) at HSPI_SonyTV.SonyTVApp.InitSonyTVClient()
    Dec-03 11:52:12 PM SonyTV INFO Initializing SonyTV Client
    Dec-03 11:52:12 PM SonyTV INFO Shutting down SonyTV Client
    Dec-03 11:49:44 PM SonyTV INFO Initializing SonyTV Client
    Dec-03 11:49:14 PM SonyTV ERROR System.Net.Sockets.SocketException (0x80004005): No connection could be made because the target machine actively refused it 10.10.10.192:20060 at System.Net.Sockets.TcpClient..ctor(String hostname, Int32 port) at SonyTV.Net.SonyTVClient..ctor(String serverAddress, Int32 serverPort) at HSPI_SonyTV.SonyTVApp.InitSonyTVClient()
    Dec-03 11:49:12 PM SonyTV INFO Initializing SonyTV Client
    Dec-03 11:49:12 PM SonyTV INFO Shutting down SonyTV Client
    Dec-03 11:35:49 PM SonyTV INFO Initializing SonyTV Client
    The other issue is actually kind of hilarious. I also run your Chromecast plugin. The TV runs Android, so whenever a voice announcement was cast, it would turn on the TV. I disabled TTS. No fix. I disabled the Chromecast. No Fix. Finally I deleted it, and that did the trick.
    Not sure what can be done about either of these things but there you go.
    Cheers.
    My home is smarter than your honor roll student.
    Ok.... so deleting it didnt fix it either. Ill try disabling tts for the other chromecast devices, and then try disabling each plug-in to try to isolate.
