It looks like the Bravia API supports up/down/left/right/select[enter]. Is there any ongoing development for this plugin going on, and is this in the roadmap? Have to decide whether to wait or build my own.
Plans to add Navigation integration?
using this plugin you can basically send any command as you would do from your remote control, so the plugin already supports navigation:
https://forums.homeseer.com/forum/au...gin-user-guide
- Likes 1
Here is the list of functions from the specifications:
IR Function Parameter
Power Off 0
Input 1
GGuide 2
EPG 3
Favorites 4
Display 5
Home 6
Options 7
Return 8
Up 9
Down 10
Right 11
Left 12
Confirm 13
Red 14
Green 15
Yellow 16
Blue 17
Num1 18
Num2 19
Num3 20
Num4 21
Num5 22
Num6 23
Num7 24
Num8 25
Num9 26
Num0 27
Num11 28
Num12 29
Volume Up 30
Volume Down 31
Mute 32
Channel Up 33
Channel Down 34
Subtitle 35
Closed Caption 36
Enter 37
DOT 38
Analog 39
Teletext 40
Exit 41
Analog2 42
*AD 43
Digital 44
Analog? 45
BS 46
CS 47
BS/CS 48
Ddata 49
Pic Off 50
Tv_Radio 51
Theater 52
SEN 53
Internet Widgets 54
Internet Video 55
Netflix 56
Scene Select 57
Mode3D 58
iManual 59
Audio 60
Wide 61
Jump 62
PAP 63
MyEPG 64
Program Description 65
Write Chapter 66
TrackID 67
Ten Key 68
AppliCast 69
acTVila 70
Delete Video 71
Photo Frame 72
TV Pause 73
Key Pad 74
Media 75
Sync Menu 76
Forward 77
Play 78
Rewind 79
Prev 80
Stop 81
Next 82
Rec 83
Pause 84
Eject 85
Flash Plus 86
Flash Minus 87
Top Menu 88
Popup Menu 89
Rakuraku Start 90
One Touch Time Rec 91
One Touch View 92
One Touch Rec 93
One Touch Stop 94
DUX 95
Football Mode 96
Social 97
- Likes 1
