scripting syntax
  • scripting syntax
    Im having trouble using hs.sendIR in vb for the square connect.
    I set up the unit to learn some IR commands for a bedroom table fan. I cant seem to get the vb syntax right for sending a power toggle IR command.
    zone= BEDROOM FAN
    signal/key=bedroom fanower toggle
    This is what Homeseer does when I use events send IR:
    [BEDROOM FAN]Bedroom_Fan,Power_Toggle
    But hs.sendIR ([BEDROOM FAN]Bedroom_Fan,Power_Toggle) throws an error
    Ive tried several different combinations, with no luck
    edit:
    got it (forgot to add the quotes):
    hs.sendIR ("[BEDROOM FAN]Bedroom_Fan,Power_Toggle")
