I have no explanation on why it needed to be broken into 2, but thank you for sharing. Hopefully it helps others trying to automate their XBox360.
Regards,
Ultrajones
Importing XBox 360 Codes
U. J.:
Thanks for the reminder about the import format - I had gotten lazy with using the IR codes directly as provided by Global Cache - stripping out the hex codes from the import file cut down the size quite a bit. Since all my import codes other than the XBox ones have worked for quite a while, I assume your code ignores the hex codes that come after the "Global Cache format" string.
After I deleted the hex codes, I found that the GCIR3 plugin did import the 2nd sendir string in each XBox command, but things still didn't work. After a little experimenting, I found that if I split the two sendir's as provided by GC into two separate commands and send them consecutively, that does work! As an example, the POWER ON was split into a POWER ON_1 and a POWER ON_2:
Code:[XBOX_POWER ON_1] sendir,1:1,1,36000,1,1,96,32,16,16,16,16,16,32,16,32,48,32,16,16,16,16,16,16,16,16,16,16,16,16,16,16,16,16,16,16,16,16,32,16,16,16,16,16,16,32,32,16,16,16,16,32,32,32,16,16,16,16,16,16,32,32,32,32,32,32,16,2476 [XBOX_POWER ON_2] sendir,1:1,1,36000,1,1,96,32,16,16,16,16,16,32,16,32,48,32,16,16,16,16,16,16,16,16,16,16,16,16,16,16,16,16,16,16,16,16,32,16,16,16,16,16,16,16,16,16,16,16,16,16,16,32,32,32,16,16,16,16,16,16,32,32,32,32,32,32,16,2476
So now the Amazon Echo can be used to turn the XBox on/off via voice commands - pretty nice. Finally, I found that the IR receiver on the XBox 360 definitely needed a stick-on Xantech IR emitter, even thought the blaster in my living room is pretty powerful and reaches most everything else easily; there appears to be a limited vertical range to the XBox 360 IR receiver.
So, there may be "cleaner" ways to make the XBox controllable, but it wasn't too painful to do what I did. I hope this helps other folks trying to control an XBox 360.
Regards,
BBB
The input file contains 2 different formats. The format should be:
[Button Name], sendir,1:1,1,[remaining-codes-removed]
I recall trying to get my Xbox 360 working several years. I recall it was quite a challenge. You may want to contact Global Cache to see if it's possible.
Regards,
Ultrajones
Bumping the thread just in case you didn't see that I uploaded my IR Import file.
Regards,
BBB
Sure - thanks! There are many devices/codes because I connect to an IR blaster.
UltraGCIR3_IR Codes Import file_2017-02-11.txt
BBB
Hello BigBadBuzz,
Can you post the import file here using a .txt extension so I can review it?
Regards,
Ultrajones
Ultra J:
I downloaded a set of codes from Global Cache's Control Tower the other night for the XBox 360. I imported those codes just like I have others from GC, but these did not control the XBox. I then noticed the codes appear to be "compounded" -- i.e., one code immediately followed by another - I've included some samples below:
Code:function, code1, hexcode1, code2, hexcode2 "#","sendir,1:1,1,36000,1,1,96,32,16,16,16,16,16,32,16,32,48,32,16,16,16,16,16,16,16,16,16,16,16,16,16,16,16,16,16,16,16,16,32,16,16,16,16,16,16,32,32,16,16,16,16,32,32,32,16,16,16,16,16,16,16,16,32,16,16,16,16,32,16,16,16,2476","0000 0073 0000 0021 0060 0020 0010 0010 0010 0010 0010 0020 0010 0020 0030 0020 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0020 0010 0010 0010 0010 0010 0010 0020 0020 0010 0010 0010 0010 0020 0020 0020 0010 0010 0010 0010 0010 0010 0010 0010 0020 0010 0010 0010 0010 0020 0010 0010 0010 09AC","sendir,1:1,1,36000,1,1,96,32,16,16,16,16,16,32,16,32,48,32,16,16,16,16,16,16,16,16,16,16,16,16,16,16,16,16,16,16,16,16,32,16,16,16,16,16,16,16,16,16,16,16,16,16,16,32,32,32,16,16,16,16,16,16,16,16,32,16,16,16,16,32,16,16,16,2476","0000 0073 0000 0022 0060 0020 0010 0010 0010 0010 0010 0020 0010 0020 0030 0020 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0020 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0020 0020 0020 0010 0010 0010 0010 0010 0010 0010 0010 0020 0010 0010 0010 0010 0020 0010 0010 0010 09AC" "A","sendir,1:1,1,36000,1,1,96,32,16,16,16,16,16,32,16,32,48,32,16,16,16,16,16,16,16,16,16,16,16,16,16,16,16,16,16,16,16,16,32,16,16,16,16,16,16,32,32,16,16,16,16,32,32,32,16,16,16,16,32,16,16,32,16,16,32,16,16,32,16,2476","0000 0073 0000 0020 0060 0020 0010 0010 0010 0010 0010 0020 0010 0020 0030 0020 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0020 0010 0010 0010 0010 0010 0010 0020 0020 0010 0010 0010 0010 0020 0020 0020 0010 0010 0010 0010 0020 0010 0010 0020 0010 0010 0020 0010 0010 0020 0010 09AC","sendir,1:1,1,36000,1,1,96,32,16,16,16,16,16,32,16,32,48,32,16,16,16,16,16,16,16,16,16,16,16,16,16,16,16,16,16,16,16,16,32,16,16,16,16,16,16,16,16,16,16,16,16,16,16,32,32,32,16,16,16,16,32,16,16,32,16,16,32,16,16,32,16,2476","0000 0073 0000 0021 0060 0020 0010 0010 0010 0010 0010 0020 0010 0020 0030 0020 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0020 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0020 0020 0020 0010 0010 0010 0010 0020 0010 0010 0020 0010 0010 0020 0010 0010 0020 0010 09AC"
Regards,
BBBTags: None
