My GCPro plugin died when I attempted to add a node. I installed te UltraCGIP plug in but can not get it working, It finds my 2 global cache devices. I used the IR tower datbase to get the commands, in this case drape open. Command below. The blaster is on port 3. And I get this strange error:
Error:
Code I am using:
"sendir,1:3,1,38000,1,1,48,16,48,16,16,48,48,16,16,48,16 ,48, 16,48,48,16,16,48,16,48,16,48,16,1327,48,16,48,16,16,48,48,1 6,16,48,16,48,16,48,48,16,16,48,16,48,16,48,16,3375","0000 006D 0000 0018 0030 0010 0030 0010 0010 0030 0030 0010 0010 0030 0010 0030 0010 0030 0030 0010 0010 0030 0010 0030 0010 0030 0010 052F 0030 0010 0030 0010 0010 0030 0030 0010 0010 0030 0010 0030 0010 0030 0030 0010 0010 0030 0010 0030 0010 0030 0010 0D2F"
thanks
Error:
Mar-23 12:35:00 PM | Warning | IR command to iTachIP2IR [192.168.2.170] module 0:0 returned error: Invalid command. Command not found. |
Mar-23 12:35:00 PM | Warning | IR command to iTachIP2IR [192.168.2.170] module 1:1 returned error: Invalid pulse count. |
thanks
