I've been using the plugin for a couple of years without much trouble. Things started getting strange after the last windows update. (I think that is when it started)
I have 2 ip units and one wifi unit, the blasters on all three are working properly. on the ip units I am getting the warning/errors below when I restart the plugin and no events are working on the first 2 ir ports. where do I start looking. I pinged the units, all responded properly. rebooted hs3, unplugged and plugged in the itachs, and changed ir leads (in case the lead failed) I don't know what to look at next.
Jun-21 10:27:56 PM Warning No response/improper response from iTachIP2IR [192.168.1.14] to command 'get_IR,1:2'
Jun-21 10:27:56 PM Warning No response/improper response from iTachIP2IR [192.168.1.70] to command 'get_IR,1:2'
Jun-21 10:27:56 PM Warning No response/improper response from iTachIP2IR [192.168.1.14] to command 'get_IR,1:1'
Jun-21 10:27:56 PM Warning No response/improper response from iTachIP2IR [192.168.1.70] to command 'get_IR,1:1'
