Hi,
I recently upgraded to HS4 and am using the HS3 plugin. I did a back-up today and notice below in the log:
A file cannot be accessed and will be skipped. If this is a plugin owned file the plugin author needs to implement the backup HSEvent: The process cannot access the file 'C:\Program Files (x86)\HomeSeer HS4\Data\ultragcir3\ultragcir3.db3' because it is being used by another process.
I tried 3 backups and all 3 give the same warning.
