Smooth Volume and HSTouch
  • Ken LaCapria
    Originally posted by rhodesep View Post
    It's in the ir command itself. Page 7 of the referenced document (count).
    I had skimmed that document and didn't pick up on the code structure. Thank you for pointing it out. Works great.
  • rhodesep
  • Ken LaCapria
    The way I handle the volume is to set the repeat level on the volume button to a high amount (at less 25) program the stopir command to be on the release of the volume button. Mine stops instantly.
    Where is the repeat level located? Is it part of the IR code or is it an HStouch setting?
    Here is one of my learned volume up code for a TV.
    sendir,$MODULE,1,37000,1,1,330,164,21,21,21,21,21,62,21,21,2 1,21,21,21,21,21,21,62,21,21,21,21,21,21,21,21,21,21,21,62,2 1,62,21,62,21,62,21,21,21,21,21,21,21,21,21,62,21,62,21,21,2 1,21,21,62,21,62,21,62,21,62,21,21,21,21,21,62,21,1525,330,8 3,21,740
  • rhodesep
    gerenb
    UltraJones implemented the method that was suggested by Global Cache' in GC-100 API Specification Version 1.0b. http://www.globalcache.com/files/docs/API-GC-100.pdf Section 5.2.3 Back-to-Back IR Commands
  • gerenb
    Sneaky - I like it. You essentially turn the volume up continuously until you lift your finger from the button. Nice.
  • Guest's Avatar
    Guest replied
    How long does a 25 repeat last? Do I need to do anything funny with the other settings (I realize that this may vary component to component)
  • rhodesep
    fuxuepeng
  • gerenb
    I don't have a solution yet. This is an important feature, though. Continuous tapping gets old.
  • Guest's Avatar
    Guest started a topic Smooth Volume and HSTouch
    Has anyone successfully implemented a volume solution that will let me hold down the volume button in hstouch until the desired volume is reached?
    Right now my thought is that in order to accomplish this I would need some kind of repeat with the HSTouch button press event, and then to send a STOPIR command with the accompanying button release event. Have any of you pulled this off?
    Thanks.
