Problem from HStouch
  • Problem from HStouch
    I have things working fine, but recently my commands from HStouch started inserting a Dim value
    LOG:
    Command sent to GlobalCache IR UltraGCIR Plugin IR Module 4:2: ^15 Value Set Dimval: 15 Data: 0
    If I go into status and send the command there or use a script it seems to work fine.
    Any ideas?
    I should add that the dim val is making it not work.
      Under Actions > ActionsWhenPressed, are you selecting an ActionType of "HomeSeer: Control a HomeSeer Device"?
      Ultrajones
        Yes, but it adds the DIm value for some odd reason.
          I also have exactly same issue.
          When I use hstouch I get s dimvslue inserted and the command is not working.
          Any ideas?
            I still cannot duplicate this. Can you provide a screenshot of the HS Touch action editor showing how you have the action configured?
              To possibly help the thread, the issue arose when I installed homeseer to windows 7. I did not change any configuration before the issue mentioned here, apart from moving the installation to a new virtual computer running windows 7 on top of KVM.
