Blank list under UltraGCIR
  • Blank list under UltraGCIR
    I bought the GC IP2IR and installed the UltraGCIR plug-in. I can see the GlobalCache SENSORs 1, 2 and 3 under status and I can access the configuration but under Import drop down menu it is blank nothing to pick. I hve used iHelp and ILearn from GC website to configure and saved the IR comands.
    Please help why I am seen blank under Import and and under IR Devices?
    Sam
    hello. Can you send me a debug output so I can see what is going on? Enable debug, then restart homeseer, then let it run for about 5 minutes, then send me the debug file located in the homeseer root directory. Send the file to ultrajones@hotmail.com.
      I still have not received a debug output. However, a blank list can occur if you restart HomeSeer and attempt to use the import function before the Global Cache devices are reconnected.
      Ultrajones
        Same Scenario here.
        I have the blank too. Working on the debug output now, but had this in the log.
        PHP Code:
        3/17/2012 9:05:48 AM  UltraPioneerAVR Er An unexpected error occured in the DiscoveryBeacon() function/subroutine:  [System.Net.Sockets.SocketExceptionAn attempt was made to access a socket in a way forbidden by its access permissions   at System.Net.Sockets.Socket.DoBind(EndPoint endPointSnapshotSocketAddress socketAddress)   at System.Net.Sockets.Socket.Bind(EndPoint localEP)   at HSPI_ULTRAPAVR.HSPI_PAVR.DiscoveryBeacon()]
        Is this a security issue? Too tight?
          When the plug-in started, it found another program already using the port. Please close all the Global Cache programs, then restart HomeSeer.
          Ultrajones
            Ultrajones
            Dang! You beat me to it! I had iLearn and iTest running. Rebooted without them and everything works great!
            ....well, except the IR learning part. Oye!
            Thanks!
            Rob
