GC-SV1 with GC-100 Not Working
  • Mike Johnson
    My conditional event was not working because an event with a trigger type of "Manual with Conditions" will only apply the conditions if it is triggered by another event (or script) with the Advanced parameter "Run Only If Conditions are TRUE" checked. I was running the event manually with the Run button next to the event, but apparently that ignores the conditions. I'm not sure why it works that way, but it seems to be working correctly if I trigger it from another event.
    Mike
  • Mike Johnson
    I changed the GC-100 connector setting from "Sensor" to "Sensor with Auto-notify" and it now seems to be updating the Homeseer Status page properly. However, I have created a couple of conditional Events based on the Active or Inactive status of the sensor, but the event executes regardless of the status. What could I be doing wrong?
    Mike
  • Mike Johnson
    started a topic GC-SV1 with GC-100 Not Working
    I installed a new GC-SV1 video sensor with my GC-100-06 but can't seem to make it work properly with Homeseer. The only way I can get the Status to update from Inactive to Active or vice versa is to restart Homeseer. Shouldn't it update the Status with a simple refresh of the Status page?
    The indicator light on the GC-100 seems to update properly when the video state is changed.
    Homeseer version: Standard Edition 2.5.0.23
    UltraGCIR plugin version: 1.1.4345.17936
    Mike
