Contacting HomeSeer This Week
See more
See less
Same codes for multiple GC IR devices
  • Same codes for multiple GC IR devices
    Just started working with the plugin and before I get to far, I want to make sure I'm not missing something.
    I have applied each output of the GC100 to a room where there is a xantech ir distribution to multiple devices in each room. So each room, has a directv receiver, meaning each output on the GC100 which corresponds to an IR device in the plugin.
    I am using the hex codes for the directv remote buttons and manually entering them into the IR device in the plugin after converting them with the GC iconvert program.
    PROBLEM: Once I enter all the directv buttons for one GC plugin device, do I have to re-enter them for another GC plugin device if I want to control another directv receiver in a different room which is associated with a different GC device? So if I have five directv receivers do I have to enter all the directv buttons (codes) 5 different times? Once for each zone (GC IR device).
    Is there a central repository for codes and then you assign them to GC IR devices, or and easy way to copy codes between devices?
    Thanks (sorry for the length)
    This is where the import function comes into play. This is a sample of what the input file should look like:
    [MENU]	sendir,1:1,1,39000,1,1,348,171,21,21,21,64,21,64,21,64,21,21,21,64,21,64,21,64,21,64,21,64,21,64,21,21,21,21,21,21,21,21,21,64,21,64,21,64,21,21,21,21,21,21,21,21,21,21,21,21,21,21,21,21,21,21,21,64,21,64,21,21,21,21,21,64,21,780
    [PLAY_PAUSE]	sendir,1:1,1,39000,1,1,348,172,21,22,21,64,21,64,21,64,21,22,21,64,21,64,21,64,21,64,21,64,21,64,21,22,21,22,21,22,21,22,21,64,21,64,21,64,21,64,21,64,21,64,21,22,21,64,21,22,21,22,21,22,21,22,21,64,21,64,21,22,21,22,21,64,21,780
    [NAV_CENTER]	sendir,1:1,1,39000,1,1,348,172,21,22,21,63,21,63,21,63,21,22,21,63,21,63,21,63,21,63,21,63,21,63,21,22,21,22,21,22,21,22,21,63,21,22,21,22,21,63,21,63,21,63,21,22,21,63,21,22,21,22,21,22,21,22,21,63,21,63,21,22,21,22,21,63,21,780
    [NAV_UP]	sendir,1:1,1,38000,1,1,348,171,21,22,21,64,21,64,21,64,21,22,21,64,21,64,21,64,21,64,21,64,21,64,21,22,21,22,21,22,21,22,21,64,21,22,21,64,21,22,21,64,21,22,21,22,21,22,21,22,21,22,21,22,21,22,21,64,21,64,21,22,21,22,21,64,21,760
    [NAV_DOWN]	sendir,1:1,1,39000,1,1,348,172,21,22,21,64,21,64,21,64,21,22,21,64,21,64,21,64,21,64,21,64,21,64,21,22,21,22,21,22,21,22,21,64,21,22,21,22,21,64,21,64,21,22,21,22,21,22,21,22,21,22,21,22,21,22,21,64,21,64,21,22,21,22,21,64,21,780
    [NAV_LEFT]	sendir,1:1,1,39000,1,1,348,171,21,22,21,64,21,64,21,64,21,22,21,64,21,64,21,64,21,64,21,64,21,64,21,22,21,22,21,22,21,22,21,64,21,64,21,22,21,22,21,64,21,22,21,22,21,22,21,22,21,22,21,22,21,22,21,64,21,64,21,22,21,22,21,64,21,780
    [NAV_RIGHT]	sendir,1:1,1,39000,1,1,348,172,21,22,21,64,21,64,21,64,21,22,21,64,21,64,21,64,21,64,21,64,21,64,21,22,21,22,21,22,21,22,21,64,21,22,21,64,21,64,21,22,21,22,21,22,21,22,21,22,21,22,21,22,21,22,21,64,21,64,21,22,21,22,21,64,21,780
      Ok, so I just create a text file like this or is there an export function?
      Thanks for the quick reply!
        I am creating an export function now. Should be available tomorrow.
        Ultrajones
          UltraGCIR HSPI version 1.1.4446.41323 was just posted. It adds an IR Export function.
          Ultrajones
            This is great, should make it easy for a lot of people to post their codes.
