Contacting HomeSeer This Week
See more
See less
GC-100 + GC-SC1 Sensor Event
  • GC-100 + GC-SC1 Sensor Event
    I am attempting to create a "device status change" event using a contact closure sensor connected to a GC-100. The plugin correctly detects that the sensor is active or inactive and debug output displays the appropriate state change information. However the event will only fire if Status is set to "Set Any Status", if I select either "Set On" or "Set Off" nothing happens. Presumably there is a way to control events based on the contact being open or closed rather than just changed?
    The status of the relay also seems to show the opposite of the actual condition, i.e. on = inactive, off = active, this is not necessarily a functional problem but does make the status interface and control workflow confusing.
    Many thanks
    Hello. You need to use a Device Value trigger instead of a Device Status trigger.
    Ultrajones
