Problems with Panasonic HVAC
  • Moskus
    I've done some more testing, and my iTach is working with the learned codes without problems at all. The GC-100 does not.
    I would get the IR codes from Panasonic, if that was an option, but they are really, really hard to find.
  • Ultrajones
    In my experience, there has been several devices that I have not been able to properly capture IR using the iTach IR learner. This looks like it could be another one of those devices. The only solution I found was to get the IR HEX codes for the device (from the vendors web site), then convert it to the GCC IR using the Global Cache converter tool.
    Regards,
    Ultrajones
  • Moskus
    I turned on debugging and got this:
    30.09.2012 13:53:44 UltraGCIR Debug Entered SetIO() subroutine.
    30.09.2012 13:53:44 UltraGCIR Debug The SetIO call was generated locally.
    30.09.2012 13:53:44 UltraGCIR Debug Sending command: 'sendir,2:3,1,36764,1,1,128,64,16,16,16,48,16,16,16,16,16,16 ,16,16,16,16,16,16,16,16,16,16,16,16,16,16,16,16,16,48,16,16 ,16,16,16,16,16,16,16,16,16,16,16,16,16,48,16,48,16,48,16,16 ,16,16,16,48,16,16,16,16,16,16,16,16,16,16,16,16,16,16,16,16 ,16,16,16,16,16,16,16,16,16,16,16,16,16,16,16,16,16,16,16,16 ,16,16,16,16,16,16,16,16,16,16,16,16,16,16,16,16,16,16,16,16 ,16,16,16,16,16,48,16,48,16,16,16,16,16,16,16,16,16,16,16,36 9,128,64,16,16,16,48,16,16,16,16,16,16,16,16,16,16,16,16,16, 16,16,16,16,16,16,16,16,16,16,48,16,16,16,16,16,16,16,16,16, 16,16,16,16,16,16,48,16,48,16,48,16,16,16,16,16,48,16,16,16, 16,16,16,16,16,16,16,16,16,16,16,16,16,16,16,16,16,16,16,16, 16,16,16,16,48,16,16,16,16,16,48,16,16,16,16,16,48,16,16,16, 16,16,48,16,16,16,48,16,16,16,48,16,16,16,16,16,16,16,16,16, 16,16,16,16,16,16,16,16,16,16,48,16,48,16,16,16,16,16,16,16, 48,16,16,16,48,16,16,16,16,16,48,16,16,16,48,16,16,16,16,16, 16,16,16,16,16,16,16,16,16,16,16,16,16,16,16,16,16,16,16,16, 16,16,48,16,48,16,16,16,16,16,16,16,16,16,16,16,16,16,16,16, 16,16,16,16,16,16,48,16,48,16,16,16,16,16,16,16,16,16,16,16, 16,16,16,16,16,16,16,16,16,16,16,16,16,16,16,16,16,16,16,16, 16,16,16,16,48,16,16,16,16,16,16,16,16,16,16,16,16,16,16,16, 16,16,16,16,16,16,16,16,16,16,16,16,16,16,16,16,16,16,48,16, 48,16,16,16,16,16,16,16,16,16,16,16,48,16,16,16,16,16,16,16, 16,16,16,16,48,16,48,16,4705' to GC device, attempt # 1
    30.09.2012 13:53:44 UltraGCIR Debug Waiting for the GC device to respond with '^completeir' for up to 2 seconds...
    30.09.2012 13:53:44 UltraGCIR Debug Entered ProcessReceived() function with string 'unknowncommand 15', waiting for '^completeir'
    30.09.2012 13:53:44 UltraGCIR Warning IR command to GC-100-06 [192.168.0.84] returned error: Maximum number of IR transitions exceeded. (SM_IR_INPROCESS)
    30.09.2012 13:53:44 UltraGCIR Debug Waited 312 milliseconds for the command response.
    30.09.2012 13:53:45 UltraGCIR Debug Entered ProcessReceived() function with string 'unknowncommand 1', waiting for ''
    30.09.2012 13:53:45 UltraGCIR Debug ProcessReceived() reports: Found '' in string 'unknowncommand 1'
    30.09.2012 13:53:45 UltraGCIR Warning IR command to GC-100-06 [192.168.0.84] returned error: Time out occurred because carriage return not received. The request was not processed.
  • Moskus
    started a topic Problems with Panasonic HVAC
    I'm trying to transmit the IR codes I've learned using the remote control for my Panasonic HVAC (CU-E9DKE) and my WF2IR iTach. The learning procedure works okay and using iLearn I can transmit the codes to the HVAC.
    However, when I import the codes to UltraGCIR, my GC-100 does not react to my codes, but it seems like my iTach works. The output port doesn't even blink when I select a code. What's going on?
    [OFF]	sendir,1:3,1,36764,1,1,128,64,16,16,16,48,16,16,16,16,16,16,16,16,16,16,16,16,16,16,16,16,16,16,16,16,16,16,16,48,16,16,16,16,16,16,16,16,16,16,16,16,16,16,16,48,16,48,16,48,16,16,16,16,16,48,16,16,16,16,16,16,16,16,16,16,16,16,16,16,16,16,16,16,16,16,16,16,16,16,16,16,16,16,16,16,16,16,16,16,16,16,16,16,16,16,16,16,16,16,16,16,16,16,16,16,16,16,16,16,16,16,16,16,16,16,16,48,16,48,16,16,16,16,16,16,16,16,16,16,16,369,128,64,16,16,16,48,16,16,16,16,16,16,16,16,16,16,16,16,16,16,16,16,16,16,16,16,16,16,16,48,16,16,16,16,16,16,16,16,16,16,16,16,16,16,16,48,16,48,16,48,16,16,16,16,16,48,16,16,16,16,16,16,16,16,16,16,16,16,16,16,16,16,16,16,16,16,16,16,16,16,16,16,16,16,16,16,16,16,16,48,16,16,16,16,16,48,16,16,16,16,16,48,16,16,16,48,16,16,16,48,16,16,16,16,16,16,16,16,16,16,16,16,16,16,16,16,16,16,16,48,16,48,16,16,16,16,16,16,16,48,16,16,16,48,16,16,16,16,16,48,16,16,16,48,16,16,16,16,16,16,16,16,16,16,16,16,16,16,16,16,16,16,16,16,16,16,16,16,16,16,16,48,16,48,16,16,16,16,16,16,16,16,16,16,16,16,16,16,16,16,16,16,16,16,16,48,16,48,16,16,16,16,16,16,16,16,16,16,16,16,16,16,16,16,16,16,16,16,16,16,16,16,16,16,16,16,16,16,16,16,16,16,16,48,16,16,16,16,16,16,16,16,16,16,16,16,16,16,16,16,16,16,16,16,16,16,16,16,16,16,16,16,16,16,16,16,16,48,16,48,16,16,16,16,16,16,16,16,16,16,16,16,16,16,16,16,16,16,16,16,16,16,16,48,16,48,16,4705
    [ON]	sendir,1:3,1,36764,1,1,128,64,16,16,16,48,16,16,16,16,16,16,16,16,16,16,16,16,16,16,16,16,16,16,16,16,16,16,16,48,16,16,16,16,16,16,16,16,16,16,16,16,16,16,16,48,16,48,16,48,16,16,16,16,16,48,16,16,16,16,16,16,16,16,16,16,16,16,16,16,16,16,16,16,16,16,16,16,16,16,16,16,16,16,16,16,16,16,16,16,16,16,16,16,16,16,16,16,16,16,16,16,16,16,16,16,16,16,16,16,16,16,16,16,16,16,16,48,16,48,16,16,16,16,16,16,16,16,16,16,16,369,128,64,16,16,16,48,16,16,16,16,16,16,16,16,16,16,16,16,16,16,16,16,16,16,16,16,16,16,16,48,16,16,16,16,16,16,16,16,16,16,16,16,16,16,16,48,16,48,16,48,16,16,16,16,16,48,16,16,16,16,16,16,16,16,16,16,16,16,16,16,16,16,16,16,16,16,16,16,16,16,16,16,16,48,16,16,16,16,16,48,16,16,16,16,16,48,16,16,16,16,16,48,16,16,16,48,16,16,16,48,16,16,16,16,16,16,16,16,16,16,16,16,16,16,16,16,16,16,16,48,16,48,16,16,16,16,16,16,16,48,16,16,16,48,16,16,16,16,16,48,16,16,16,48,16,16,16,16,16,16,16,16,16,16,16,16,16,16,16,16,16,16,16,16,16,16,16,16,16,16,16,48,16,48,16,16,16,16,16,16,16,16,16,16,16,16,16,16,16,16,16,16,16,16,16,48,16,48,16,16,16,16,16,16,16,16,16,16,16,16,16,16,16,16,16,16,16,16,16,16,16,16,16,16,16,16,16,16,16,16,16,16,16,48,16,16,16,16,16,16,16,16,16,16,16,16,16,16,16,16,16,16,16,16,16,16,16,16,16,16,16,16,16,16,16,16,16,48,16,48,16,16,16,16,16,16,16,16,16,16,16,48,16,16,16,16,16,16,16,16,16,16,16,48,16,48,16,4705
    I get these errors in the log:
    30.09.2012 13:15:28 Device Control Device: Media UltraGCIR Plugin GC-100 - 3 Stue ([17) Value set to 348
    30.09.2012 13:15:29 UltraGCIR Warning IR command to GC-100-06 [192.168.0.84] returned error: Maximum number of IR transitions exceeded. (SM_IR_INPROCESS)
    30.09.2012 13:15:30 UltraGCIR Warning IR command to GC-100-06 [192.168.0.84] returned error: Time out occurred because carriage return not received. The request was not processed.
