So I took the advice of some users on this forum and decided to use the UltraGCIR HSPI plugin instead of the Homeseer Global Cache plugin. Now I need some help setting up the plugin to detect contact closure status change. So far I don't see anything being detected in the logs. This is what I've done so far:
1. Setup iTachWF2IR device and set Connector 1 to Sensor Notify, use port 9132, and Notify Timer to 0.
2. Installed UltraGCIR and confirmed the GlobalCache Sensor_Notify device is active.
I've touched the two wires together on the GC-SC1 and watched the Homeseer logs but nothing shows up. What needs to be done to the plugin to detect status changes? Thanks in advance for any help you are able to lend
