Sporatic Error Message
  • Sporatic Error Message
    UltraJones,
    Every hour on the hour I have a script that sends an "OK" IR string to my uVerse STB to keep it from going to sleep after six or so hours on a single channel (documented uVerse work around!). Maybe once a day I get the following error message, the balance of the time it works perfectly. Wondering if you had any off the top thoughts. I am on version 1.1.4446.41323. I will enable debugging here in a sec and follow with logs as soon as it happens again.
    <TABLE border=0 cellSpacing=2 cellPadding=0 width="100%"><TBODY><TR><TD class=LOGDateTime1 noWrap align=left>/14/2013 4:00:03 PM </TD><TD class=LOGType1 colSpan=3 align=left>UltraGCIR Warning </TD><TD class=LOGEntry1 colSpan=8 align=left>No response/improper response from iTachIP2IR [192.168.1.80] to command 'sendir,1:1,21,38000,2,1,15,11,6,11,6,24,6,11,6,30,6,17,6,11 ,6,11,6,11,6,24,6,24,6,17,6,24,6,17,6,17,6,30,6,11,6,3320,15 ,11,6,11,6,24,6,11,6,30,6,17,6,11,6,11,6,11,6,24,6,24,6,17,6 ,24,6,17,6,17,6,30,6,11,6,3289'</TD></TR></TBODY></TABLE>
    Thank you,
    Chris
    I have a couple of commands for turning on TVs (where I have had to set the repeat quite high) that generate the same error message. The commands always work though so I just ignore the error message.
    Nicolai L
      That warning message indicates the first attempt at sending the IR did not generate the proper response from the Global Cache device. It you don't see an "error", then the second attempt succeed.
      Ultrajones
