Missing Codes
    Missing Codes
    Setting up events, I find that codes are missing from the drop-down list
    Example "Enter".. it shows in the IR Code, but it is not on the drop-down
    Ubuntu on the Intel NUC ( 8i5BEK ), 32 G, 250G SSD, V4 Pro 😎
    here's "0"
    from file..
    [DTV - 0] sendir,<mod-addr>:<conn-addr>,13,39000,<repeatcount>,1,232,46,46,46,23,23,23,23,23,4 6,23,23,23,46,23,46,46,23,23,1155,116,44\,46,23,23,46,23,23, 23,23,23,23,23,46,46,46,23,23,46
    here's log..
      Why is there a "\" in the IR code section of the entry?
        see the post above it.. it was a cut and paste job.. will check to see if all got copied
        thanks
        Geary
          not the problem...
            got to be something simple... all do the same
            back to the RTFM mode..
              error code
              still working it... this is the error i now get
                Please provide the IR export for the IR device you are having a problem with along with the GC-100-12 firmware version and a detailed explanation of the problem so I can attempt to duplicate the issue.
                Regards,
                Ultrajones
                  really simple.. just trying to get any button to work to the new DirecTV receiver.. If you can give me the code for example a "1', I can probably figure out what i am doing wrong..
                  see may 18th post above ( removed the / )
                    Okay, I think I found the issue. The IR codes you provided appear to be the output of the iConvert program. You'll need to use the Global Cache iLearn program, then save those results to a file so they can be imported.
                    In order to resolve this issue, you can simply copy the output from iConvert into the Edit View text area of the iLearn program, then enter the button name, then click "Save Data". Repeat this process until all buttons are converted, then click "New File" to save the file so it can be imported into the UltraGCIR HSPI. You could also try to change "&lt;mod-addr&gt;:&lt;conn-addr&gt;" to 1:1 and &lt;repeatcount&gt; to 1.
                    I'll look into detecting the output from iConvert so others don't have to struggle with this. Sorry for not noticing earlier.
                    Regards,
                    Ultrajones
                      Regards,
                      Ultrajones
                      Thanks.. have a long week-end, will get a chance to play.. How close are you to HS3... I have it up and LOVE it...
                        looks like that was it.. will finish config when you are ready for HS3
