iTach Flex
  • iTach Flex
    Has anyone used iTach Flex yet?
    It's pretty interesting that the same device can function as WIFI/LAN to Serial or WIFI/LAN to Infrared by just switching the cable. Somewhat cheaper than WF2IR and IP2IR too.
    On top of being backward compatible with GC-100 and previous iTach devices, it introduces 2 more control path (via web), I suppose to cater to the mobile (iOS, Android)?
    Anyway, I've just ordered a (wired) iTach Flex + 3 port IR cable to replace my GC-100-12 which cannot handle IR commands for Daikin and Mitsubishi Mr.Slim airconditioners.
    HW: HS3 w/ Win8.1 on ASRock C2550d4i. Digi AnywhereUSB, Hubport, Edgeport, UZB, Z-trollers, PLCBUS, SONOS, GC-100, iTach IP2SL, WF2IR, IP2IR, RFXtrx433, Harmony Hubs, Hue, Ademco Vista 128BP, NetAtmo, NetAtmo Welcome
    Google Search for HomeSeer Forum
    It works with HS2 UltraGCIR
    Even though it is not official. My Flex was recognized by UltraGCIR. My flex is a single Blaster. GCIR finds it as 1:1. I loaded Power on/off codes for 4 devices and all works fine. This Blaster actuality works (unlike the BL2 Blaster).
    ULTRA the link to your documentation above is broken.
      I've got my flex, with the tri-port cable. Unfortunately GCIR doesn't recognize that it's a device with 3 output and only shows up as a 1:1 node.
      It seems that iTach Flex is not supported yet by UltraGCIR.
      Ultrajones, can we get this fixed please?
        I just unboxed my iTachFlex. It is a pretty neat device. I'll get UltraGCIR HSPI updated to support the iTachFlex before starting the HS3 conversion. It may take up to 2 weeks before I can post an update though ...
        Ultrajones
          I have the Global Cache Flex working with any combination of IR devices connected. I now have to figure out how to code it so that if you connect a serial device to one of the tri-ports, it doesn't display it as an IR device. Almost there ...
          Ultrajones
            It looks like the tri-port cable and the serial cable cannot be used at the same time, so I think the coding changes are complete. I'll post an update shortly that adds support for the Global Cache iTach iFlex.
            Ultrajones
              Ultrajones
              HS2 or HS3?
                The update is to UltraGCIR HSPI for HS2.
                  I just posted UltraGCIR HSPI version 1.1.4999.26515 that adds support for the Global Cache iTach Flex.
                  Ultrajones
                    I had my flex working before the upgrade. I only have a single IR blaster. I have a tri cable but I am not using it. New version will not find Flex. Old version found it an it worked. Should I do something special?
                    update: The flex is appearing in the status as Wifi module 0:1. It does not appear when I go to the plugin to input codes.
                      I was wrong
                      iTech Flex is not showing up. Ultramon detects it but, ultraGCIR does not.
                        Can you tell me what firmware version you are using? I believe the latest is 710-2000-07.
                        Ultrajones
                          Ultrajones
                          I am on 710-2000-07. I had been using the flex since it arrived on the last software. Since I only using one BL and no tri cable. The last version found it. I learned the codes and all worked.
                            New information
                            Randy
                            There is a new iHelp (ver 4.3) which upgrades the firmware to 710-2000-09.
                            You will have to shutdown HS2 to run iHelp that will load the firmware. Guess what, the iTach Flex showed up when I restarted HS2. The device and codes I had entered were still there. It seems to be working OK.
                            Thanks, Gene
                              Serial Commands?
                              Hi guys - I have a 2 iTach Flexs. One is being used in triport IR and works great (in early testing). My other one is a serial connection.
                              Did you ever get the iTach Flex Serial to work? You mention the code is complete. It shows up as a Serial device to me and is discovered just fine by HS3. However, I can't figure out how to send Serial commands. I already know the strings to send.
                              The documentation mentions IR triggers, but I am not sure how to apply that to serial.
