UltraGCIR3 HSPI - Bug Reports
This is a sticky topic.
    #31
    UJ - Firstly any update on the IR Control tab in Firefox?
    Secondly - When I quit HS3 UltraGCIR3 (and UltraNetCam3) crash with a dialog that says "HSPI_UltraGCIR3 has stopped working"
    Author of Highpeak Plugins | SMS-Gateway Plugin | Blue Iris Plugin | Paradox (Beta) Plugin | Modbus Plugin | Yamaha Plugin
      #32
      Hello beerygaz. No updates on the IR control tabs yet. I had planned on re-witting the routines using jquery, but have not had time yet.
      I am not sure why the plug-ins are crashing on shutdown. I have never seen this before. When did it start? What version of HS are you using? What operating system are you using?
      Ultrajones
        #33
        UJ, it started around 3.0.0.42 - but I can't be 100% sure. I'm running 3.0.0.54 now, Windows Server 2008 R2 OS.
          #34
          Ultrajones
          I can report the crash on the shut down of HS3 is happening here too. I only enable the plug-in for short periods of time, then disable it and other plug-ins before handing back control to HS2. When I shutdown HS3, I get the Windows dialog that it has crashed. Running Win7 and on version 0.54.
          I can try enabling, then shutting down to see if the crash happens all the time or just after it has been disabled if that would help.
          Barry
          Edit: OK tried a couple of variations and got the message when the plug-in was enabled and shut HS3 down. However, that only occurred once in three tests. I also got a clean shutdown with the plug-in disabled just now. If you would like for me to try anything, let me know.
            #35
            I am getting frequent occurrences of the following warning in my error log:
            Jan-08 11:39:46 AM Warning In ZipFile, exception opening C:\Program Files\HomeSeer HS3\Data\ultragcir3\ultragcir3.db3 : The process cannot access the file 'C:\Program Files\HomeSeer HS3\Data\ultragcir3\ultragcir3.db3' because it is being used by another process.
            Jan-08 11:32:13 AM Warning In ZipFile, exception opening C:\Program Files\HomeSeer HS3\Data\ultragcir3\ultragcir3.db3 : The process cannot access the file 'C:\Program Files\HomeSeer HS3\Data\ultragcir3\ultragcir3.db3' because it is being used by another process.
            I don't have a recurring event setup for UltraGCIR3. The only rule I have right now is that it triggers the PIP on my TV when the doorbell rings to display our front door camera, and show us a picture of who is standing there. These warnings do not correspond to when the event is triggered.
              #36
              This error isn't something from my plug-in. Do you have some type of backup job running that is trying to access ultragcir3.db3?
              Ultrajones
                #37
                Barry
                This is a confirmed issue on systems running Windows 7. It has something to do with the .Net Framework. It does not happen on Windows 8. I am still looking into it.
                  #38
                  Ultrajones
                  That was it UltraJones. I am moving over to HS3, and recreating all of my events, so I am doing frequent 'Backup Config' under the Tools/Setup menu. Every time I run that, the warning appears.
                    #39
                    Last edited by FredrikKan; January 29, 2014, 11:48 AM. Reason: Update on sw versions
                      #40
                      Ping
                      "Is there anybody out there...?"
                        #41
                        this is what I get.. is the port avail > ( 4998) ?
                        what o/s are you running
                        Ubuntu on the Intel NUC ( 8i5BEK ), 32 G, 250G SSD, V4 Pro
                          #42
                          Hello Fredrik. The error is occurring within a section of the code provided by HomeSeer. Are you able to get the sample plug-in installed and working on Microsoft Windows HomeSeer 2011?
                            #43
                            Hi UJ!
                            I'm not sure what you mean with sample plugin...? I do have other plugins working (almost) ok. There are quite a lot of small problems/bugs but nothing compared to the startup problem with UltraGCIR3.
                            Windows home Server 2011 is a variant of MS 2008 Server and use the same codebase. I have used it for HS2 for the last 2-3 years with no problems. Before that I used the original Windows Home Server (based on MS 2003 Server).
                            All that is fine and have not been an issue with Homeseer. From what I have read it is supported.
                            I've included the other plugins currently installed in my system.
                            Fredrik.
                              #44
                              Tried HS3 forum with no success
                              Ultra,
                              according to Rupp you should get in contact with them regarding this problem. I would really lika you to do that!
                              And maybe give me some feedback....
                                #45
                                I sent Rich a note and asked him to look at the issue you posted at http://board.homeseer.com/showpost.p...5&postcount=39
                                Ultrajones
