Have started to move from HS2 to HS3. A large portion of the system is used to control whole house audio and video via IR. Under HS2 was using the Homeseer Global Cache plugin with repeating IR commands for volume up and down. This worked well. When moved to HS3 and the UltraJones plugin, the commands do not repeat even though they work perfectly when tested with the Global Cache ilearn utility.
These commands should repeat 25 times
[BK_VOL_UP_X25] sendir,4:1,1,36000,25,1,330,164,22,62,22,62,22,18,22,62,22,6 2,22,18,22,18,22,18,22,18,22,62,22,62,22,62,22,18,22,18,22,6 2,22,18,22,18,22,18,22,62,22,18,22,18,22,62,22,18,22,18,22,6 2,22,62,22,18,22,62,22,62,22,18,22,62,22,62,22,3601
[BK_VOL_DOWN_X25] sendir,4:1,1,36000,25,1,330,163,22,62,22,62,22,19,22,62,22,6 2,22,19,22,19,22,19,22,19,22,62,22,62,22,62,22,19,22,19,22,6 2,22,19,22,62,22,62,22,19,22,19,22,19,22,62,22,19,22,19,22,1 9,22,19,22,62,22,62,22,62,22,19,22,62,22,62,22,3601
If the repeat is changed from 25 to a higher number (500) there is still no repeating.
What am I doing wrong?
