ving problems with gc-100-12
    I have been using the UltraGCIR plug in in Hs2 for awhile with a wifi contact closure device and it is working great today I started to add 2 GC-100-12 units the plug in creates devices for them but I am unable to get commands to send to them. I am using the ilearn software to learn the IR codes with the GC-IRL I am able to communicate with the devices using global caches test software.
    I had these sent in and flashed to the latest firmware.
    I set the debug log and this is what I am receiving when I try to send an IR command.
    1/20/2014 5:58:41 PM UltraGCIR Debug Sending command: 'sendir,4:1,1,38000,1,1,342,169,22,20BB22,62CCBBCCCBBBCCBCBB CBBBCBCCBCCC22,3800' to GC device, attempt # 1
    1/20/2014 5:58:41 PM UltraGCIR Debug Waiting for the GC device to respond with '^completeir' for up to 1 seconds...
    1/20/2014 5:58:41 PM UltraGCIR Debug Entered ProcessReceived() function with string 'unknowncommand 10', waiting for '^completeir'
    1/20/2014 5:58:41 PM UltraGCIR Warning IR command to GC-100-12 [192.168.1.72] returned error: Number of transitions in the IR command is not even (the same number of on and off transitions is required).
    1/20/2014 5:58:41 PM UltraGCIR Debug Waited 38 milliseconds for the command response.
    1/20/2014 5:58:45 PM UltraGCIR Debug DiscoveryBeacon: Global Cache unit iTachWF2CC [192.168.1.73] is alive.
    1/20/2014 5:58:46 PM UltraGCIR Debug Entered GetGCIRData() function.
    1/20/2014 5:58:46 PM UltraGCIR Debug Entered GetGCIRDevices() function.
    1/20/2014 5:58:47 PM UltraGCIR Debug Watchdog Timer indicates a response from the Global Cache device [192.168.1.72] was received at 1/20/2014 5:58:41 PM.
    1/20/2014 5:58:47 PM UltraGCIR Debug Watchdog Timer indicates a response from the Global Cache device [192.168.1.72] was received 6 seconds ago.
    1/20/2014 5:58:47 PM UltraGCIR Debug Watchdog Timer thread for the Global Cache device [192.168.1.72] sleeping for 30000.
    1/20/2014 5:58:47 PM UltraGCIR Debug Sending command: 'getversion' to GC device, attempt # 1
    1/20/2014 5:58:47 PM UltraGCIR Debug Waiting for the GC device to respond with '.+' for up to 1 seconds...
    1/20/2014 5:58:47 PM UltraGCIR Debug Entered ProcessReceived() function with string 'version,0,3.2-12', waiting for '.+'
    1/20/2014 5:58:47 PM UltraGCIR Debug ProcessReceived() reports: Found '.+' in string 'version,0,3.2-12'
    1/20/2014 5:58:47 PM UltraGCIR Debug Waited 23 milliseconds for the command response.
    1/20/2014 5:58:48 PM UltraGCIR Debug Sending command: 'sendir,4:1,1,38000,1,1,342,169,22,20BB22,62CCBBCCCBBBCCBCBB CBBBCBCCBCCC22,3800' to GC device, attempt # 1
    1/20/2014 5:58:48 PM UltraGCIR Debug Waiting for the GC device to respond with '^completeir' for up to 1 seconds...
    1/20/2014 5:58:48 PM UltraGCIR Debug Entered ProcessReceived() function with string 'unknowncommand 10', waiting for '^completeir'
    1/20/2014 5:58:48 PM UltraGCIR Warning IR command to GC-100-12 [192.168.1.72] returned error: Number of transitions in the IR command is not even (the same number of on and off transitions is required).
    1/20/2014 5:58:48 PM UltraGCIR Debug Waited 90 milliseconds for the command response.
    someone please help
    Thanks Ken
    EDIT: I finally got it working, it didn't like the remote I was trying to learn the codes from, now that I got that figured out all is running great hoping to add a few more in the near future.
    Thanks Ultra for the great plug in
    Cheers Ken
    HSPRO,HS3PRO, BLsecurity, , MCSxap, HSTouch Android, UltraGCIR, CM15a, USBUIRT, BLUSBUIRT, WIFIRGB, BLAB8SS, BLcontrol, BLGData, BLLAN,BLOccupied, BLRadar, BLVolume, iTunesDAAP, UltraGCIR3, Airplayspeak, BLalarm, BLbackup, BLLED, BLrandom, BLReminders, BLRF, BL Speech, Hyperion, IFTTT, KINECT, XBMC, MCSprinkers PRO, PHLocation, ULtrapioneer, Ultralog, ultraweatherbug, Z,troller, GC-100, GC WIFICC, GC-WIFI SERIAL, Nitrogen logic depth camera controllers,
