Global Cache IR Database
This is a sticky topic.
    I just updated the UltraGCIR3 HSPI to support the Global Cache IR database. The IR Database is designed to allow you to search for IR Codes in a database of devices. Simply point your browser at http://www.globalcache.com/irdatabase
    I'm have an issue that I desperately need help on. I import the database of IR codes but where in Homeseer do I send the IR commands. I do have quite a bit of Homeseer experience but 0 and I mean zero Global Cache plug in experience. Help I am trying to get them designated with names so I can use Alexa for commands. HELLLLLP
      Which plugin and which hardware are you using? I'm using the UltraGCIR3 along with several GlobalCache wifi transmitters (e.g., Flex, https://www.globalcache.com/products/flex/). Elliott
      "Living with technology means living in a [constant] state of flux." S. Higgenbotham, 2023
        I'm using the Global Cahe Pro and the iFlex IR WiFi
          I'm sorry, I am not going to be able to help, since I am not familiar with that plugin. Elliott
