HS3 initial setup
  • HS3 initial setup
    I just installed the HS3 version trying to get this one to work better than Homeseers plugin.
    As an FYI, this is my first attempt at using a global cache product.
    I tried following the help but it is for the HS2 version.
    What I have done so far:
    Enabled the plugin, went to options and added the IP address of the Global Itach IP2IR device I have. I didn't do this at first because I thought this plugin automatically discovered the device.
    Then the plugin wanted me to restart Homeseer which I did. I try to go to any of the tabs and I do not see the device listed. All dropdowns are blank.
    I have iHelp running and it shows the device on my network.
    Am I doing something obviously incorrect? Do I need to add IR commands to the device before the plugin discovers it? I have not added any IR commands as of yet.
    The help file for UltraGCIR3 is available on the HS3 help page. Go to Tools - Help.
    Cheers
    Al
      Thanks I will look at it. I am use the "Help" being under the plugin tab where the config location is.
        I still can't get this plugin to recognize the device.
        I went back to Homeseers plugin and it found the device and was able to "learn" DirecTV's power button and was able to deploy it through the test button so I know the device is working.
        I noticed the LG TV commands were posted on another thread since that is the TV I have but have not had any luck getting those "learned".
        Without the device being seen by this plugin I can't import those commands either.
        Any help would be appreciated.
          A few things to check:
          • Make sure the other HomeSeer plug-ins and any Global Cache programs are not running. If running, they my prevent my plug-in from listening on the UDP multi-cast group.
          • Confirm you installed the UltraGCIR3 plug-in from the system running HomeSeer. You should have seen a Windows firewall prompt asking if you authorize the UltraGCIR3 plug-in to listen for incoming packets.
            I can confirm I did get the windows firewall prompt and I selected Allow.
            I did have Homeseer's plugin enabled as well as yours. I disabled theirs, removed the IP from the Options Page, and restarted Homeseer.
            That seemed to have worked Seems I have tried all this before but didn't work oh well, it works now.
            Now I will start the IR assigning and see if I have any other questions.
            Thank you.
              I was able to import the IRs for the LG TV and all is good!
                Is this plugin supported for linux?
                I just got a HomeTroller-SEL running HS3 Standard Edition 3.0.0.143 (Linux). I don't see the UltraGCIR in the list of available plugins. Is this only available for HS3 for windows?
                  No, it's not working with Linux yet. I'll modify the plug-in to support Linux soon.
                  Ultrajones
                    Hi Ultrajones
                    any estimation for hs3 linux UltraGCIR support ?
                    i really like to move to work with a linux machine to be the control center.
                    TZach
                      My target date is 13 days from Today.
