Adding IR codes issue
  • Adding IR codes issue
    I am running HS2Pro. I am using a GC-100-12. I use a GC-IRL connected to COM1 to learn the IR codes to add to the database. I use a GC-IRE connected to COM2 to read IR codes I have programmed as triggers.
    I have 200+ IR codes in the database and 6 trigger IR codes.
    All works perfectly and is very reliable. However, if I learn new IR codes and add them to the database, I loose the IR triggers and have to relearn them. Is there a way to add new IR codes to the database and not clobber the trigger codes?
    Ken <!-- / message -->
