Problem with IR Codes
  • Problem with IR Codes
    I installed the plugin and the iTach WF2IR devices created automatically. Everything (hardware wise) appears fine and dandy.
    I then sat down and used the iLearn to learn the Sony Remote for my old Receiver (STR-DE695). This setup will be going into the garage.
    I saved the file.
    And loaded it in the plugin. Ensured that the codes imported.
    Then... I tried to test turning the receiver on... no dice.
    I went back to iLearn and re-learned the Power button on the remote. Tried to "Send IR" and nothing happened.
    Googled / Youtubed but I'm at a loss.
    I've changed the ports and switched between the ir blaster and ir emitters and nothing changes.
    Is there some secret handshake that I'm missing here?
    Can you attach your file? I have a Sony receiver and can try and test the file with it.
    Cheers
    Al
      Are there any settings that I should have changed in iLearn?
      The file contains:
      [RECON] sendir,1:1,1,40064,1,1,9,11,4,24,10,2,1,2,30,24,48,24,24,24, 24,4000
      [RECOFF] sendir,1:1,1,40064,1,1,16,4000
      [RECVID3] sendir,1:1,1,39936,1,1,96,24,24,24,48,24,24,24,24,24,24,24,2 4,24,48,24,24,24,24,24,24,24,24,24,48,24,48,24,24,24,24,887, 96,24,24,24,48,24,24,24,24,24,24,24,24,24,48,24,24,24,24,24, 24,24,24,3900
      [RECVID1] sendir,1:1,1,40192,1,1,22,24,24,24,48,24,24,24,24,24,24,24,4 8,4000
      [RECVOLUP] sendir,1:1,1,40192,1,1,13,4000
      [RECVOLDOWN] sendir,1:1,1,19936,1,1,89,11,6,11,1,4,2,1900
      [RECMUTE] sendir,1:1,1,32051,1,1,75,19,24,19,24,19,48,19,24,19,48,19,2 4,3200
        To allow it to be used by any port, change it to:
        [RECON]	sendir,$MODULE,1,1,40064,1,1,9,11,4,24,10,2,1,2,30,24,48,24,24,24, 24,4000
        It looks like you may have had some learning issues as the frequency changes quite a bit between commands (40064,39936,40192,19936,32051). I would focus on one command and get it working from IRLearn.
          There's also a file posted here:
          http://board.homeseer.com/showpost.p...12&postcount=4
          Maybe try that one instead of yours. It needs to be edited with the $MODULE variable as well.
          Cheers
          Al
            And take a look at the Global Cache database as it has the codes for your receiver: http://board.homeseer.com/showthread.php?t=169873.
            It gives the power on command as:
            sendir,1:1,1,40638,1,1,95,24,24,24,48,24,48,24,48,24,24,24,48,24,24,24,24,23,24,24,24,23,24,24,47,1065
            Cheers
            Al
              You might try to repeat the signal three times. GC support suggested this to me for Sony stuff.
              Don
                All fixed.
                For future reference it seems that the Sony products need the repeat set to 2.
                And to import your IR codes from the global cache db not the remote (works soo much better).
                One other issue I came across was a bad ir blaster, have to replace it (thankfully the ir emitters work fine).
                Thank you everyone for chiming in!
                  I have an old Sony projector in the basement that requires 5 repeats. Once I figured that out it works like a charm.
                  cheeryfool
