"updateButton()" error
  • "updateButton()" error
    I had the dreaded USB HUB Error 43 pop up the other day and long story short I had to "Refresh" my Win 8.1 system and reload HS3 from backup.
    When I send a command from the IR Device Control I get the error message: ("updateButton()". Element is undefined). No idea what this means but obviously no signals are being sent.
    I also see the following in the start-up log:
    Dec-04 6:46:45 AM Warning File does not exist: C:\Program Files (x86)\HomeSeer HS3\html\hspi_ultragcir3\css\lightbox.css
    When I send a signal from the IR Control page I receive the error message "sendirByld()" as well.
    I can't control a single TV in the house and it's driving me nuts!
    update
    OK, i switched browsers and i'm no longer getting that message but when i try to import IR codes i get the following in the HS Log:
    Posting back to plugin web page UltraGCIR3: Object reference not set to an instance of an object.-> at System.Runtime.Remoting.Messaging.LogicalCallContext.Propaga teIncomingHeadersToCallContext(IMessage msg) at System.Runtime.Remoting.Proxies.RealProxy.PrivateInvoke(Mess ageData& msgData, Int32 type) at HomeSeerAPI.IPlugInAPI.PostBackProc(String page, String data, String user, Int32 userRights) at Scheduler.proxyPage.postBackProc(StateObject& state, String Data)
    Dec-04 1:06:51 PM Warning Plugin UltraGCIR3 is not responding but it is still running, not restarting yet.
    Dec-04 1:06:51 PM Error Posting back to plugin web page UltraGCIR3: Object reference not set to an instance of an object.-> at System.Runtime.Remoting.Messaging.LogicalCallContext.Propaga teIncomingHeadersToCallContext(IMessage msg) at System.Runtime.Remoting.Proxies.RealProxy.PrivateInvoke(Mess ageData& msgData, Int32 type) at HomeSeerAPI.IPlugInAPI.PostBackProc(String page, String data, String user, Int32 userRights) at Scheduler.proxyPage.postBackProc(StateObject& state, String Data
    All of the GC units show connected but it doesn't appear any commands are being sent.
    I reinstalled the plug-in and that worked well. As soon as I enable the plug-in I see the following in the log:
    Dec-04 1:12:54 PM Informational Ethernet connection established to 192.168.1.172:4998
    Dec-04 1:12:54 PM Informational DiscoveryBeacon: Global Cache unit GC-100-12 [192.168.1.172] discovered.
    Dec-04 1:12:48 PM Informational Ethernet connection established to 192.168.1.103:4998
    Dec-04 1:12:48 PM Informational DiscoveryBeacon: Global Cache unit GC-100-12 [192.168.1.103] discovered.
    Dec-04 1:12:36 PM Warning No response/improper response from iTachWF2IR [192.168.1.39] to command 'get_IR,1:3'
    Dec-04 1:12:35 PM Warning No response/improper response from iTachIP2IR [192.168.1.215] to command 'get_IR,1:3'
    Dec-04 1:12:34 PM Warning No response/improper response from iTachWF2IR [192.168.1.39] to command 'get_IR,1:3'
    Dec-04 1:12:33 PM Warning No response/improper response from iTachIP2IR [192.168.1.215] to command 'get_IR,1:3'
    Dec-04 1:12:32 PM Warning No response/improper response from iTachWF2IR [192.168.1.39] to command 'get_IR,1:2'
    Dec-04 1:12:32 PM Warning No response/improper response from iTachIP2IR [192.168.1.210] to command 'get_IR,1:3'
    Dec-04 1:12:31 PM Warning No response/improper response from iTachIP2IR [192.168.1.215] to command 'get_IR,1:2'
    Dec-04 1:12:30 PM Warning No response/improper response from iTachWF2IR [192.168.1.39] to command 'get_IR,1:2'
    Dec-04 1:12:30 PM Warning No response/improper response from iTachIP2IR [192.168.1.210] to command 'get_IR,1:3'
    Dec-04 1:12:29 PM Warning No response/improper response from GC-100-12 [192.168.1.135] to command 'get_IR,4:2'
    Dec-04 1:12:29 PM Warning No response/improper response from iTachIP2IR [192.168.1.215] to command 'get_IR,1:2'
    Dec-04 1:12:28 PM Warning No response/improper response from iTachWF2IR [192.168.1.214] to command 'get_IR,1:2'
    Dec-04 1:12:28 PM Warning No response/improper response from iTachWF2IR [192.168.1.39] to command 'get_IR,1:1'
    Dec-04 1:12:28 PM Warning No response/improper response from iTachIP2IR [192.168.1.210] to command 'get_IR,1:2'
    Dec-04 1:12:27 PM Warning No response/improper response from iTachWF2IR [192.168.1.39] to command 'get_IR,1:1'
    Dec-04 1:12:27 PM Warning No response/improper response from iTachIP2IR [192.168.1.215] to command 'get_IR,1:1'
    Dec-04 1:12:26 PM Warning No response/improper response from iTachIP2IR [192.168.1.215] to command 'get_IR,1:1'
    Dec-04 1:12:26 PM Warning No response/improper response from iTachWF2IR [192.168.1.214] to command 'get_IR,1:1'
    Dec-04 1:12:26 PM Warning No response/improper response from iTachIP2IR [192.168.1.210] to command 'get_IR,1:2'
    Dec-04 1:12:25 PM Warning No response/improper response from iTachWF2IR [192.168.1.214] to command 'get_IR,1:1'
    I also see this when I try to send a code from IR Control tab on some of the devices:
    File does not exist: C:\Program Files (x86)\HomeSeer HS3\html\hspi_ultragcir3\images\ajax-loader.gif
      Restoring your system from backup appears to have left your system in an unknown state. Have you tried to run the Microsoft Framework repair tool? It may be helpful to contact HomeSeer to see if they have instructions to do that.
      Ultrajones
