"sendirbyld()" Function Error
  • "sendirbyld()" Function Error
    Using iLearn and GC iTach WF2IR, I have recorded a button press to a .txt file and verified that the button press does turn on the TV. However, after importing it into UltraGCIR, I receive the error message "error occurred in the sendirbyld()" function. Number undefined. window.event undefined".
    Help! I do not have a clue.
    The IR learning mechanism on the iTach is not worth your time in my opinion. You should be able to download all the IR commands for your device from Global Cache (https://irdb.globalcache.com/), then import them into the plug-in which saves hours of your time.
    Ultrajones
      Thanks for the reply.
      I did both the iLearn and the import from the source you indicated, one for the first ir output channel and the other for the 2nd. I got the same error message. I will try deleting the code and re-importing after work today.
      Dennis
