Hello,
I am trying to create an event that will trigger when my doorbell is rung which is tied into my HTD whole home audio system.
When the doorbell is rung, the HTD system will switch on all zones and set them to a source input of "Intercom". This works fine. However, that source does not seem to get reported back into the HS3 source device for some reason. If I change the source to any other input on the system, it is reported as expected.
The end goal here is to have HomeSeer reset any zones that were not in use when the doorbell rang and to also power those zones off.
Any thoughts on why that input does not get reported back in properly?
Current Date/Time: 5/6/2018 7:34:08 PM
HomeSeer Version: HS3 Pro Edition 3.0.0.368
System Uptime: 6 Days 21 Hours 57 Minutes 11 Seconds
IP Address: 172.20.10.14
Number of Devices: 235
Number of Events: 68
Available Threads: 1023
Enabled Plug-Ins
2.0.54.0: BLOnkyo
3.0.0.16: Chromecast
3.1.2.3: MeiKu
3.0.6092.18438: UltraHTDAudio3
3.0.1.190: Z-Wave
Attached are two screenshots of the same device. One screenshot when it is set to an input I have a Chromecast connected too and another when it is set to the Intercom input. You will notice that nothing is read back on the device when the source is set to Intercom.
Under the plugin screen on the "Audio Zone Devices" tab, it shows a value of 18 when it is set to intercom, but I don't see this anywhere that I have found to reference in an event.
Any help is appreciated.
Thanks a lot!
-Landon
Enabled Plug-Ins
2.0.54.0: BLOnkyo
3.1.2.3: MeiKu
3.0.1.190: Z-Wave
Thanks a lot!
-Landon
