I have had the UltraHTDAudio3 plugin installed and working fine for well over a year. I'm now getting the following error logged several hundred times upon startup.
Error Message:
While troubleshooting, I have renamed the C:\Program Files (x86)\HomeSeer HS3\Data\ultrahtdaudio3\ultrahtdaudio3.db3 and allowed HomeSeer/UltraHTDAudio3 plugin recreate the file. Doing so requires me to setup the Audio Controller, but oddly everything still appears to function OK when controlling my HTD system from HomeSeer.
System Information:
Any idea how I fix this issue?
Error Message:
System.Data.SQLite.SQLiteException (0x80004005): SQL logic error or missing database near "sRm": syntax error at System.Data.SQLite.SQLite3.Prepare(SQLiteConnection cnn, String strSql, SQLiteStatement previous, UInt32 timeoutMS, String& strRemain) at System.Data.SQLite.SQLiteCommand.BuildNextCommand() at System.Data.SQLite.SQLiteCommand.GetStatement(Int32 index) at System.Data.SQLite.SQLiteDataReader.NextResult() at System.Data.SQLite.SQLiteDataReader..ctor(SQLiteCommand cmd, CommandBehavior behave) at System.Data.SQLite.SQLiteCommand.ExecuteReader(CommandBehavi or behavior) at System.Data.SQLite.SQLiteCommand.ExecuteNonQuery() at HSPI_ULTRAHTDAUDIO3.hspi_plugin.UpdateAudioZoneSource(Int32 source_id, String source_name_keypad)
System Information:
Current Date/Time: 2/17/2019 11:35:52 AM
System Uptime: 0 Days 0 Hours 34 Minutes 21 Seconds
IP Address: 192.168.245.134
Number of Devices: 248
Number of Events: 28
Available Threads: 400
HSTouch Enabled: True
Event Threads: 0
Event Trigger Eval Queue: 0
Device Exec Queue: 0
HSTouch Event Queue: 0
Email Send Queue: 0
In Virtual Machine: No MFG: intel corporation
Enabled Plug-Ins
1.5.0.0: MQTT
0.0.0.42: Pushover 3P
3.0.6922.16287: UltraHTDAudio3
3.0.6768.36584: UltraM1G3
Event Threads: 0
Email Send Queue: 0
Enabled Plug-Ins
1.5.0.0: MQTT
