I'm changing the volume with the dropdown-list and within scenes.
I've got a Pioneer VSX-921 and running Homeseer in Linux with Mono 5 (mono 3+4 also had this issue).
Error when changing volume
Hi, are you changing the volume using the HomeSeer volume device or using your remote control on your receiver? What type of receiver do you have?
When I change the volume I get the following message.
Code:Error System.ArgumentException: Argument 'Expression' cannot be converted to type 'System.Int64'. at Microsoft.VisualBasic.Conversion.Val (System.Object Expression) [0x000b3] in :0 at HSPI_ULTRAPIONEERAVR3.hspi_pioneeravr.GetPioneerAVRVolumeLimt (System.String pavr_uuid, System.String vol_limit, System.Double vol_limit_default) [0x000ae] in <894c3e585f8143159c90dc33c5e4e986>:0 Error System.ArgumentException
Tags: None
