Need Toggle
  • Need Toggle
    I just installed a Elite VSX-33 that I am using with your Plugin. I could not find any documentation for script calls. So I have a feature request. Please add "toggle" to the existing device list that have "on & Off". This will keep me from adding two buttons per function on my Ipad.
    I am in complete agreement! Please add toggle to all of the functions.
      Yes, will try to get to this this weekend. Should be an easy feature to add.
        Sweet! On a similar vein, could you look at something that would allow an incremental volume up, and an incremental volume down? This would be very helpful from HSTouch.
        Thank you.
          russdonnan
          I am using a "slider" with some success. My VSX-33 goes form -80db (1) to +12db (185). I set the slider at max 185 and min at 1. It works but is very erratic.
            I'm using a script to change the device value by 2db. Below is my volume down script:
            &hs.SetDeviceValue("\11", hs.devicevalue("\11")-2)
              I was able to add a toggle to the following:
              1) Master volume, zone2 volume, zone3 volume
              2) Master mute, zone2 mute, zone3 mute.
              Note: Looks like everything else already had a cyclic option.
              Simply delete the previous HomeSeer device, then re-create it. Note: Delete and re-create them one at a time if you want to re-use the existing HomeSeer device code.
              Ultrajones
