Your plugin appears to be terrific -- but some quick questions:
1. I have multiple PIO receivers..will your plugin support more than one -- and if not, when might i expect that functionality.
2. Do you support the VSX-94txh? It has RS232 support. It also has Ethernet connectivity, but am not sure if remote control is available via IP. In any event, support for either would be good.
3. The computer running homeseer is distant from the receiver. I wish to use a Global Cache GC-100 to connect to the Pioneer (via RS232). Is this use case supported?
Thanks in advance!
suresh
Thanks in advance!
suresh
