VSX-1121 Problem
  • VSX-1121 Problem
    Hi, I purchased a new VSX-1121 when the getting was good and now trying out this plug-in.
    Having problems keeping things operating properly - see error below
    4/14/2012 8:45:57 AM UltraPioneerAVR Warning No response/improper response from Pioneer AVR device '192.168.1.37:23' to command '?P'. Your Pioneer AVR may not support the feature 'Power'.
    4/14/2012 8:46:01 AM UltraPioneerAVR Warning No response/improper response from Pioneer AVR device '192.168.1.37:23' to command '?P'. Your Pioneer AVR may not support the feature 'Power'.
    4/14/2012 8:46:32 AM UltraPioneerAVR Error An unexpected error occured in the SendMessageToEthernet() function/subroutine: [System.IO.IOException: Unable to write data to the transport connection: An existing connection was forcibly closed by the remote host. --- System.Net.Sockets.SocketException: An existing connection was forcibly closed by the remote host at System.Net.Sockets.Socket.Send(Byte[] buffer, Int32 offset, Int32 size, SocketFlags socketFlags) at System.Net.Sockets.NetworkStream.Write(Byte[] buffer, Int32 offset, Int32 size) --- End of inner exception stack trace --- at System.Net.Sockets.NetworkStream.Write(Byte[] buffer, Int32 offset, Int32 size) at HSPI_ULTRAPAVR.PioneerAVR.SendMessageToEthernet(String Message)]
    4/14/2012 8:46:35 AM UltraPioneerAVR Warning Ignoring command '?P' because the Pioneer AVR device '192.168.1.37:23' is not connected.
    4/14/2012 8:46:36 AM UltraPioneerAVR Warning No response/improper response from Pioneer AVR device '192.168.1.37:23' to command '?P'. Your Pioneer AVR may not support the feature 'Power'.
    4/14/2012 8:46:38 AM UltraPioneerAVR Warning Ignoring command '?P' because the Pioneer AVR device '192.168.1.37:23' is not connected.
    4/14/2012 8:47:11 AM UltraPioneerAVR Warning Watchdog Timer indicates Connection to Pioneer AVR device '192.168.1.37:23' was lost.. Attempting to reconnect ...
    4/14/2012 8:47:32 AM UltraPioneerAVR Warning Watchdog Timer reconnect attempt failed.
    If anyone knows what the problem might be or what I may be doing wrong I would welcome some help. Thx in advance.....
    You need to configure the AVR to always accept telnet connections even when the AVR is powered off (plugged in but power toggled off). There is a menu setting to set it. That will fix at least some of those logs from popping up.
    The ?P thing... I'd learn to live with that log...
    huggy_d1
    Automating made easy
      Thanks, that did the trick - don't know how I missed that screen while doing the setup.
