looking for Pioneer amp.
  • looking for Pioneer amp.
    Anyone selling a used Pioneer amp?
    Hector
    Win.2003 OS, HS3
    MyTrigger,ACRF2,W800,Zwave
    AP800,Honeywell Stat
    The VSX-1122-K is the 2012 model and is only $419 at newegg.com.
    Ultrajones
      Plug question?..
      It seams that I have a eye on a Pioneer VSX 30 which is in good condition, but I have a question. When HS emits TTS will it be transmitted thru the RS 232 connection or will it be connected to one of the inputs of the receiver as a normal audio device?
      Hector
      Win.2003 OS, HS3
        Vsx-1022 $299
        http://www.newegg.com/Product/Produc...-82117410-L01A
          Does these model have all requirements like serial port and ethernet connection?
          Hector
          Win.2003 OS, HS3
            It has an ethernet connection. It works with the plug-in. It also allows you to stream music to it through iTunes via the network.
            I have the 1120 (2011 model) and love it. I've always owned a Pioneer receiver and this one is the best one yet. (Cheapest, too!)
              Thanks for pointing the link Outbackrob ...
              I was just wondering what's the difference between the 1022 and the 1122? Is there anything more on the newer model that would warrant getting the 1122.
              I couldn't tell for sure, but does the 1022 have the party mode? I am mostly interested in integrating with HS for control and also with my iPhone/iPad.
              Is there a must have feature on the 1122? I really like the price of the 1022.
                Are you using the unit for TTS for HS?
                Hector
                Win.2003 OS, HS3
                  No, I'll use it in the living room to connect to the TV, maybe stream some internet radio.
                  So if anyone can give me some differences, I'd appreciate it. Still tossing the idea
                    Do you use it for TTsS for HS?
                    Hector
                    Win.2003 OS, HS3
                      No. I am actually using a $10 amp I bought at Best Buy 20+ years ago in a scratch-n-dent sale.
                      You can use ANY amp for TTS and HS output. The only real requirement is that is it powerful enough to drive whatever speakers you are using.
                      If you are asking if you can use send HS output over the Ethernet to the Pioneer, I don't know for sure, but I don't think so.
                      The beauty of this series of Pioneer amps is that they are EXTREMELY configurable, nearly completely controllable with Untra's plug-in, and relatively inexpensive.
                      Rob
                        When I was looking last year, the only difference in the 1021 and the 1121 was the video processor. This is from Ultra:
                        Originally posted by Ultrajones
                        The video processor on the VSX-1121-K uses Marvel with Qdeo Video Proccessing while the video processor on the VSX-1021-K uses Anchor Bay. The VSX-1121-K including the ability to convert incoming analog component signals to 1080p HDMI.
                        Ultrajones
                        The quality of the video from my 1121 is spectacular.
                        Rob
                          Rob
                          I know that ou can use any amp for TTS, but the feature to switch speakers from one room to another sounds makes a difference.
                          Hector
                          Win.2003 OS, HS3
                            Can you just run the HS speaker client audio output to an audio input, and on TTS with interruption allowed, switch inputs, pause a small amount for the PAVR plugin to update the input currently selected, then push the TTS message, use the PAVR plugin to revert the plugin's input back to whatever it was (remember to save it so you can get back to it, but of course you know this).
                            If you use an NETv device, you can push the message onto the HDTV screen using a script.
                            huggy_d1
                            Automating made easy
                              Are you currently doing this yourself?
                              Hector
                              Win.2003 OS, HS3
