looking for Pioneer amp.
Originally posted by Rotech View PostAre you currently doing this yourself?
I tested these types of things, which is why I know it would result in low WAF. The NEtv was the next best option, but even then, it's iffy. I would rather use a kindle fire with a pop-up screen and option audio amps with speakers in rooms I'd want the TTS to activate.
Right now, I use the PAVR to set the sound levels for center and surround channels (+x.x dB) as it greatly increases WAF. I liked the surround being more precise and what the sound editors intended, but that means the surround speakers often sound like they aren't doing much (until you crank them up).
I use HSTouch integration to select various inputs and control playback. Many things became simpler with UJs PAVR plugin.
Originally posted by Rotech View PostI know that ou can use any amp for TTS, but the feature to switch speakers from one room to another sounds makes a difference.
If you use an NETv device, you can push the message onto the HDTV screen using a script.
Originally posted by outbackrob View PostNo. I am actually using a $10 amp I bought at Best Buy 20+ years ago in a scratch-n-dent sale.
You can use ANY amp for TTS and HS output. The only real requirement is that is it powerful enough to drive whatever speakers you are using.
If you are asking if you can use send HS output over the Ethernet to the Pioneer, I don't know for sure, but I don't think so.
The beauty of this series of Pioneer amps is that they are EXTREMELY configurable, nearly completely controllable with Untra's plug-in, and relatively inexpensive.
Rob
Originally posted by bernieb View PostThanks for pointing the link Outbackrob ...
I was just wondering what's the difference between the 1022 and the 1122? Is there anything more on the newer model that would warrant getting the 1122.
I couldn't tell for sure, but does the 1022 have the party mode? I am mostly interested in integrating with HS for control and also with my iPhone/iPad.
Is there a must have feature on the 1122? I really like the price of the 1022.
Originally posted by UltrajonesThe video processor on the VSX-1121-K uses Marvel with Qdeo Video Proccessing while the video processor on the VSX-1021-K uses Anchor Bay. The VSX-1121-K including the ability to convert incoming analog component signals to 1080p HDMI.
Regards,
Ultrajones
Rob
Rob
Originally posted by outbackrob View PostIt has an ethernet connection. It works with the plug-in. It also allows you to stream music to it through iTunes via the network.
I have the 1120 (2011 model) and love it. I've always owned a Pioneer receiver and this one is the best one yet. (Cheapest, too!)
No, I'll use it in the living room to connect to the TV, maybe stream some internet radio.
So if anyone can give me some differences, I'd appreciate it. Still tossing the idea
Originally posted by Rotech View PostDoes these model have all requirements like serial port and ethernet connection?
Plug question?..
It seams that I have a eye on a Pioneer VSX 30 which is in good condition, but I have a question. When HS emits TTS will it be transmitted thru the RS 232 connection or will it be connected to one of the inputs of the receiver as a normal audio device?
