Hello Dave,
Can you try to delete, then recreate the volume device?
Regards,
Ultrajones
UltraPioneerAVR HSPI - Support for 22 New 2012 and 2013 Pioneer Receivers
This is a sticky topic.
Pioneer VSX-1130 Volume issue
I use the UltraPioneerAVR3 plugin to manage my VSX-1130 home theater receiver. After working through some issues (with your help thank you) I have been able to put the TV, DVR, and receiver remotes away… for the most part.
I had been controlling my receiver for about a week and all of a sudden I cannot change the volume (+/-) using the UltraPioneerAVR3 Homeseer Plugin. Unlike other plugins, like your UltaGCIR3 product, I do not upload commands to control the Pioneer receiver and therefore do not know what action I might take to correct the volume issue. If there is a troubleshooting FAQ you can point me at or other steps I should take, please advise.
Dave
I finally gave up on the 1130 and am buying a SC-1223. Meanwhile I have been playing with my old VSX-1020 and the plug-in and discovered it works fine with the UltraPioneerAVR! It is not on the list so I naturally assumed it would not work since it was not on the list and stupid me I never even downloaded the plugin for a trial to even test it till now. I have the plugin trial going on and had it working with the VSX-1130 i just returned.
After finding a web site that listed the commands and another that demonstrated how to telnet to the receiver to test if it supports network control I then had to manually add it to the Plugin config and Wow it works fine and controls my main zone and can even power on and off the zone 2 and sources like I have always wanted Homeseer to have control of! Had to manually add the model number, MAC address, and IP with port 8102.
Only thing it does not do is allow power on over the network. I appears it does not have the Network standby option like the supported receivers. Easy enough to work around and use IR control to power it On then plugin control from there.
All this time I have missed out on having some automation control of my receiver. Just wanted to pass this on to others. Unfortunately the receiver keeps shutting down and has a failed amplifier and will soon be replaced by a SC-1223. I am most definitely purchasing the plugin and would have purchased the HS3 version sooner as well as purchased it back int the HS2 days if I had known it might have worked.
I probably missed the message thread about trying it on the non supported model.
I just got my new VSX-1130 installed and am trying the plugin in trial mode. I have one small problem with the plugin. I have a simple 5.1 setup in HDzone speaker setup. I have a second set of speaker on my patio as a second zone. I finally figured out looking at last changed times that Zone 4 in the plugin is the HDZone that i have setup.
I can turn on power to the HDzone via Zone4 in the plugin but none of the source selections work.
Does anybody else have a 1130 setup with a second zone?
Last commentt is a gripe about the Pioneer 1130. In the second HDZone you can not select analog or coax/optical source to play. Really ruins my setup to play Sonos content to the second outside patio zone.
I may end up returning thing thing because of that. My old 2009 VSX-1020 did not have the problem. It would only play analog sources out to the second zone but it worked fine with a Sonos ZP.
Originally posted by Ultrajones View PostSee this post: http://board.homeseer.com/showpost.p...40&postcount=1
Originally posted by jlrichar View PostDoes the plugin work with vsx-45? Is there a comprehensive list someplace? I just see the list at the top of this post and a few shorter ones in this thread.
Originally posted by morrisdlx View PostAl,
I contacted Homeseer as directed. They issued me a new thirty day license so that I could reinstall and work out my issues. As part of the process, I deleted the VSX-1130k entry on the Receiver page and deleted all Pioneer devices. I reinstalled the plug-in using the Homeseer provided license. At this point, I am getting the following message on the Installed Plug-ins, Plug-in Status entry, “WARNING: Failed getting InterfaceStatus from UltraPioneerAVR3 - the interface was not found in the list of active interfaces, the list may need to be refreshed.”
The AVR3 plug-in is not listed on the Plug-ins drop down list.
I disabled and re-enabled the Plug-in and the warning was removed. The Plug-in is now listed in the Plug-in drop down.
At this point, no receivers are listed on the RCVR tab. During all of the actions above the receiver was connected to the LAN and turned off as stated in the earlier steps.
Please advise.
Dave
Regards,
Ultrajones
Install and Setup issues
Al,
Please advise.
Dave
Originally posted by morrisdlx View PostUltrajones,
I really want to make this work. If I can get the trail license renewed, I will send a detailed step by step information on the install, tests, and results. Is there a way to refresh the trail license and try again?
Dave
Cheers
Al
Originally posted by Ultrajones View PostThe logs you provided looks like you were trying to control the UltraPioneerAVR plug-in devices by changing the device string which won't work. You have to control the plug-in devices by changing its value.
Regards,
Ultrajones
Dave
The above was every log entry while trying to execute pioneer devices. At this point, my trial license has expired. I would really like to be able to integrate my VSX-1130-k Pioneer receiver but, at this point I am stumped.
I have some significant network work to complete and need to work on other plugins for surveillance cameras. When this is completed, I will review the current inputs for 1130 specific installations.
Thank you for taking the time to look over my log data.
Dave
Regards,
Ultrajones
I am not seeing any output from my plug-in in the log data you provided.
Regards,
ultrajones
Dave
Originally posted by karlito View Posthello
i want use this plugin but it writes me :
warning : failed getting interfacestatus from ultrapioneer avr3 - the interface was not found in the list of active interfaces , the list may need to be refreshed.
i dont understand why ?
i uninstalled the installed but not works
Regards,
Ultrajones
