Hi Randy,
Occasionally I get the error messages below in my HS log. I'm suspecting that this is caused by a network interruption and that the plugin can't talk to the receiver at that time. Would it be possible to intercept these errors and provide a warning message in the log instead?
Al
Al
Mar-01 5:05:11 PM 1 Error System.IO.IOException: Unable to write data to the transport connection: An existing connection was forcibly closed by the remote host. ---> System.Net.Sockets.SocketException: An existing connection was forcibly closed by the remote host at System.Net.Sockets.Socket.Send(Byte[] buffer, Int32 offset, Int32 size, SocketFlags socketFlags) at System.Net.Sockets.NetworkStream.Write(Byte[] buffer, Int32 offset, Int32 size) --- End of inner exception stack trace --- at System.Net.Sockets.NetworkStream.Write(Byte[] buffer, Int32 offset, Int32 size) at HSPI_ULTRAPIONEERAVR3.PioneerAVR.SendMessageToEthernet(String Message) Mar-01 5:05:11 PM 1 Error System.IO.IOException
