Dear Ultrajones,
I am moving from HS2 to HS3. I have had problems in HS3 getting the plug in to connect to my Pioneer LX55 and SC86. The symptoms as follows:
Do you have any advice to get the SC86 to connect to the plug in?
Willm
- Loaded up the plug in and it detected both receivers automatically.
- Both receivers were disconnected, so the options to set up devices were all greyed out.
- They would not connect from the root device reconnect option.
- I re-booted both receivers to get them to re-establish their connections. No effect.
- I gave up for a few days.
- I returned to find that LX55 had connected and so I was able to set up the devices I wanted. It has been working fine since (about 4 days).
- SC86 still will not connect, so I can't configure it. I have tried resetting the network in the receiver, no effect and i have repeatedly selected the disconnect and reconnect option.
- I went back to HS2 to find that it was also not connecting to my SC86, so I guess it is a problem with settings on the SC86. Network standby is on. IP is on DHCP and Port 4 is set to 00023.
Willm
