Error on Network Interruption
    Hi Randy,
    The UltraPioneer plugin is working great for me overall. I have one request though. When I have a network interruption, the following errors are shown in the log:
    Feb-01 5:01:39 PM 1 Error System.IO.IOException: Unable to write data to the transport connection: An existing connection was forcibly closed by the remote host. ---> System.Net.Sockets.SocketException: An existing connection was forcibly closed by the remote host at System.Net.Sockets.Socket.Send(Byte[] buffer, Int32 offset, Int32 size, SocketFlags socketFlags) at System.Net.Sockets.NetworkStream.Write(Byte[] buffer, Int32 offset, Int32 size) --- End of inner exception stack trace --- at System.Net.Sockets.NetworkStream.Write(Byte[] buffer, Int32 offset, Int32 size) at HSPI_ULTRAPIONEERAVR3.PioneerAVR.SendMessageToEthernet(Strin g Message)
    Feb-01 5:01:38 PM 1 Error System.IO.IOException
    Could this be changed to a Warning with maybe a shorter message? I think the UltraGCIR plugin has similar messages when it looses its connection to my GC devices, so if that could be changed as well, that would be great.
    Al
    Hi Randy,
    Have you had a chance to consider this?
    Al
      Yes, that's been on my todo list for a while. I need to catch the System.IO.IOException exception and write a friendly "Unable to Connect" message. However, I still feel it should be an error instead of a warning.
      Ultrajones
        I have updated the UltraPioneerAVR3 plug-in to write a friendly error. In this case, the new error will be: Attempted to write to a closed Ethernet stream in SendMessageToEthernet()
        I'll post it in a few minutes.
        Ultrajones
          Originally posted by sparkman View Post
          Hi Randy,
          Al
          Hi Al, I reviewed the code for UltraGCIR3 HSPI and I am unable to locate where that verbose error is being written. Can you provide a sample please?
          Ultrajones
            Ultrajones
            Great, thanks Randy!
            Ultrajones
            Will try to replicate it and post it when I do.
            Al
              Hi Randy,
              Here's the one from UltraGCIR. It's quite a bit shorter already, so not as bad
              Feb-06 7:18:04 AM Error Ethernet connection could not be made to 192.168.1.xx:4998 - A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond 192.168.1.xx:4998
              Al
