I purchased the russound plugin last week. After some trial and error I'm making progress.
I would like to use the russound keypad in my master bath to control the tv and av sources. I was able to create an event that turns off the tv by using the "device had its value set to (off). So when I press the off button it will turn off russound zone and turn off the tv.
I would also like to use other buttons to trigger actions, like have the "+" button on the keypad change the tv channel. I can't find where to see this action taking place. Is there a way to use a button like this?
I'm using the global cache pro plugin to send the IR commands.
