I can use the Tivo Channel text input field and Submit button to change the channel on a Tivo. That works.
However, the entry shown in the log doesn't reflect the channel number change. Don't know if that's an error or not. I entered "509" in the control field, tapped the Submit button and the channel changed. But this is what listed in the Event Log:
I should point out that other events that use the Tivo Channel as a 'changes and becomes' trigger DO work properly.
Sep-18 6:13:56 PM | Device Control | Device: TiVo Channel Gym Gym Tivo to (0) by/from: CAPI Control Handler |
